Drive it like u stole it.
Timing idler gears
I am making progress assembling my motor and ran across this. Before I button up the timing chains can someone weigh in on this sloppiness of the idlers? Am I missing something here? I have updated idlers that do not require the old spacer, but there is this gap now. Am I to assume that these will just center under tension and fall into place? Just wanting to be sure before I seal this up.
See video short: https://www.youtube.com/shorts/g1lnHZ2wWxI See image below:
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ Last edited by jonesb930; 08-18-2024 at 12:00 PM.. |
There is nothing missing that’s so there is some centering of the chain available.
Bruce g |
Bill
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Rosco_NZ
The cover will restrict movement .. but you do want the adjuster shaft to be central on the adjuster foot.
Rosco_NZ
From memory I had to machine a little off the face of the tensioner to ensure they aligned correctly .. which is when the tensioner is all the way in on the shaft. |
