High CR pistons for Carrera 3.0 engine
Hi guys,
I'm started on the rebuild of my 911 Carrera 3.0 engine. Not sure yet but I might want to upgrade the pistons to JE/Wossner with a higher CR. As the engine bore is 95mm I see a lot of sets for sale for an SC engine. The difference however is that the carrera 3.0 engine uses the 2.7 crank 6 bolt crank. From what I read the small end of the connecting rods is wider on these than the later SC engines. Will SC pistons fit on the wider connecting rods? Thanks, Jesse
Jesse '76 911 backdate with Carrera 3.0 engine |
The 75/77 euro used the Mahle 93L7 which went into later 78/79 USA production
Across the board, your build should be good. Wrist pins were all same diameter, 22mm, through SC production, except the turbo 3.3 used 23mm wrist pins Bruce |
Here's the specs for 2.4-2.7 and C3 vs SC 3.0
back in the day Andial had a 9.5 95mm CIS p/c set and a 9.8 95mm MFI p/c set
the only thing I see today in the Mahle catalog is stock
Try not, Do or Do not
The 3.1 L Wedge
The pistons are designed to use 3.3 liter turbo rings so replacement is affordable and easy. $ 3.575.00 plus shipping We also have a new version in stock and ready to ship. The new version has a wedge dome to more accurately replicate the original 3.1L Porsche 911SC-Leistungsgesteigert performance kit. $ 3.775.00 plus shipping.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Is that price for pistons only or?
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
This is offered as a kit.
Special order pistons are just that, special order. We are not a parts house per se. We are engine builders offering something special that we use in house.
Thanks for the replies guys!
