Jesse911's Avatar
High CR pistons for Carrera 3.0 engine
Hi guys,
I'm started on the rebuild of my 911 Carrera 3.0 engine. Not sure yet but I might want to upgrade the pistons to JE/Wossner with a higher CR.
As the engine bore is 95mm I see a lot of sets for sale for an SC engine. The difference however is that the carrera 3.0 engine uses the 2.7 crank 6 bolt crank. From what I read the small end of the connecting rods is wider on these than the later SC engines. Will SC pistons fit on the wider connecting rods?
Thanks,
Jesse
Jesse
'76 911 backdate with Carrera 3.0 engine
Old 01-30-2025, 07:30 AM
The 75/77 euro used the Mahle 93L7 which went into later 78/79 USA production
Across the board, your build should be good. Wrist pins were all same diameter, 22mm, through SC production, except the turbo 3.3 used 23mm wrist pins
Bruce
Old 01-30-2025, 08:43 AM
Bill Verburg's Avatar
Originally Posted by Jesse911 View Post
Hi guys,
Thanks,
Jesse
A '76-77 Carrera 3.0 used the same rods as the 2.4s and 2.7s
Bill Verburg
Old 01-30-2025, 09:22 AM
Here's the specs for 2.4-2.7 and C3 vs SC 3.0
Bill Verburg
Old 01-30-2025, 09:57 AM
back in the day Andial had a 9.5 95mm CIS p/c set and a 9.8 95mm MFI p/c set
the only thing I see today in the Mahle catalog is stock
Bill Verburg
Old 01-30-2025, 01:52 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The 3.1 L Wedge
Engine type 930.03 or 930.09 * 3.1 *
Engine displacement: 3122 cc
Bore x Stroke: 97mm x 70.4mm
Power: 210 hp @ 5900 rpm Binary: 280 Nm @ 4300 rpm
0 at 100 km / h: 6.4 seconds Max speed: 230 km / h
The Forgotten 911SC-L
Porsche's 1st factory tuning engine kit that was NOT in the option list for those years (Dealer Secret)
Rolf Sprenger, The Father of the Porsche MFI for the road cars and the Slant Nose 930
Designed this 3.1, 210hp Tuning kit for customers that were not happy with the output and performance of the normal 911SC 3.0 78-81
This tuning kit has a output of 210HP @5800 RPM and 206 Torque @ 4700rpm
Roth used 97mm 3.3 Turbo Cylinders with 9.5:1 compression Pistons made it 3122CC
3.1-L Engine Leistungsgesteigert or Increased Power
Bosch reworked the CIS injection with new Distributor
Taller 5th gear and larger oil cooler from the race department
3750.00 dollar Option in 1978
ONLY spread word of mouth at Porsche Dealers showroom
when customers voiced displeasure of the performance of a normal 911SC
Never was available in the USA only Europe and ROW and only a Letter from Rolf was included in the glove box with this upgrade
No way of knowing how many of these tuning kits were made
Some estimate 200-300 unit made
Roth Sprenger Personal notes and Porsche refusal to Market the SC-L
almost left no documentation to this special rare 911
We're making sets using 95mm cylinders bored to 97mm and plated by Millennium. CP X-brace pistons are then custom fitted. Any compression (with reason) is available but we stock a 10:1 version on the shelf.
The pistons are designed to use 3.3 liter turbo rings so replacement is affordable and easy.
$ 3.575.00 plus shipping
We also have a new version in stock and ready to ship.
The new version has a wedge dome to more accurately replicate the original 3.1L
Porsche 911SC-Leistungsgesteigert performance kit.
$ 3.775.00 plus shipping.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-30-2025, 04:16 PM
prschmn's Avatar
Is that price for pistons only or?
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 01-31-2025, 08:20 AM
This is offered as a kit.
Special order pistons are just that, special order.
We are not a parts house per se. We are engine builders offering something special that we use in house.
Henry Schmidt
Ph: 760-728-3062
Old 01-31-2025, 08:46 AM
Jesse911's Avatar
Thanks for the replies guys!
Jesse
Old 02-03-2025, 12:49 PM
