Air flow tins installed.
Taking things slow.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-23-2025, 02:40 PM
Rings
Thanks for the info, I’ll check with Mahle, but I think the new P&C 3.0 to 3.2 ring sizes are different. I thought you had reconditioned an old set.
Old 02-23-2025, 03:20 PM
Banned
dedyplay's Avatar
Very nice
Old 02-26-2025, 02:57 AM
Had a few hours today to clean and prep the camshaft housings.
Old 03-09-2025, 03:23 PM
i too got new cylinders from Mahle. And I had a problem to get a good seal to the heads, because my cylinders were not chamfered. While the cut in the heads is radiused. Put the heads on in the vertical. Also do leakdown to verify they seal before proceeding. I ended up chamfering the cylinders. Fixed it
80SC (ex California)
Old 03-15-2025, 11:05 AM
Dang it, I wish I had read this earlier. I just put the heads on and the cam housings this morning. I’ll check before I proceed further.
Old 03-15-2025, 02:49 PM
Arrow
I don’t see any issues with the heads sealing.
Old 03-15-2025, 06:28 PM
agree. maybe I was unlucky. When I installed my heads 1-3 was installed vertical. None of these leaked. Heads 4-6 were installed with engine flat. 2 of these leaked. Maybe my issues came from my heads had been recut 0.25mm and radius could be different.
Old 03-16-2025, 02:52 AM
I appreciate the “heads” up it was a good idea to check.
Old 03-16-2025, 05:40 PM
Arrow
A little progress, chain boxes installed, cam shafts and sprockets are on.
Old 03-16-2025, 05:46 PM
Nice work, looks beautiful! I am hoping to catch up to you with my build here in a few days, just waiting on a few more parts.
Old 03-16-2025, 10:21 PM
Chain Sprocket Alignment.
2 shims on the left and 4 shims on the right.
Left side:
Right Side:
Old 03-17-2025, 11:36 AM
Thanks. I hope your parts arrive soon and your build goes great.
Old 03-19-2025, 07:22 PM
following this ! I have similar build and also the same k75 cams on order. One question on ring gap you have 0.0175 ring gaps. A lot more than porsche build specs. Why ? Asking because I was confused with the CP/Carillo gap specs compared to porsche specs. I am thinking air cooled aluminium cylinders vs cast iron and different thermal expansion. Circumference (length of piston ring that expands) of a 98mm bore vs a 95 mm bore is insignificant
Old 03-20-2025, 12:00 AM
DIY wrencher
Very nice work with great attention to little details Shane and Ian! Taking notes for my engine building file, will be spending some extra time for parts prep to avoid leakage and scratches in these very expensive P&Cs!
Hi Trond,
Can you please explain or ideally show a picture where you would place a chamfer on the cylinder? I get it for the heads since the chamber is sized for a 95mm bore, so that it matches the bigger bore below.
Cheers,
Lukas
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 03-20-2025, 04:21 AM
Got my missing ring and moving along. Hope to have the chain boxes and cams installed today.
Old 03-20-2025, 09:04 AM
Thumbs up
Good question, the rings were gapped at 0.0175” right out of the box, so I couldn’t get less gap if I wanted to. Fortunately that is right where we needed them and on the edge of Mahle recommendations. The gap determination involved Ian’s experience and consultation with other renowned builders.
Old 03-20-2025, 05:09 PM
Arrow Set up for timing.
Ready to get timing.
#1 valve lash adjusted.
Mechanical chain tensioners in place.
Verified TDC and all timing marks.
Old school degree wheel mounted to the fly wheel. Wheel of fortune style.
Old 03-21-2025, 07:10 PM
Arrow
The plan was to get timing done tomorrow, but things went smoother and quicker than expected and I’m done or I screwed something up and I’ll figure it out tomorrow.
A quick call to William Marshall got the Cam card and directions to set these up at 0 valve lash, 050” at 27 degrees before TDC.
Both camshafts installed with the key ways pointed up and sprockets pinned.
Left side (1,2,3) From TDC I turned the crank until #1 valve was at .050” then removed the pin, rotated the crank until the degree wheel was at 27 degrees before TDC, and put the pin back in. Checked by turning the crank two revolutions while verifying on the second rotation that at 27 degrees before TDC the intake valve was at .050”. It was.
Then to the right side (4,5,6) key way was pointed down. Installed rocker on #4 and dial gauge, adjusted valve lash to zero. Rotated crank until crank until #1 valve was at .050” then removed the pin, rotated the crank until the degree wheel was at 27 degrees before TDC, and put the pin back in. Checked by turning the crank two revolutions while verifying on the second rotation that at 27 degrees before TDC the intake valve was at .050”. It was.
I’ll adjust valve lash to running spec tomorrow and check that each side is at .047” at 27 degrees before TDC. degrees. I’ll double check everything and valve to piston clearances as well.
Old 03-21-2025, 07:51 PM
Timing is done, rockers installed and valves adjusted.
Old 03-26-2025, 05:48 PM
