Did you replace the oil coolers?
Old 05-20-2025, 10:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Arrow Back at it!
After completing an autopsy, I’m resurrecting this build using all serviceable parts and replacing all non serviceable parts.
Today I was able to get all of the bottom halves cleaned out and checked the piston squirters. Oil pump, intermediate gears and chains, and all bearings are installed. Not a speck of metal was found.
I replaced the crankshaft. Replaced the stock rods with Carrillo rods and bolts, and used standard bearings.
Bolts were tightened to .0065” stretch.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-24-2025, 04:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Unfortunately the more engines you do the faster you get.I love my ultrasonic cleaner..
I'm not picking my nose..I'm porting my upper intake manifold.
Old 05-26-2025, 12:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Thumbs up
Mine is not large enough for an engine. But it does make cleaning easier.
Got the case halves together today. Everything is spinning smoothly.
Old 05-26-2025, 01:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Cool Deck heights and compression ratio
All deck heights are measured and adjusted to .040” (+/- .001”)
Old 05-28-2025, 07:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Jesse911's Avatar
Nice work!
Jesse
'76 911 backdate with Carrera 3.0 engine
Old 05-29-2025, 03:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Set up for cam timing tomorrow.
Old 05-29-2025, 07:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Arrow
Timing is done. Lightweight flywheel is on. Lower valve covers are prepped.
All I need now is a twin plug distributor….
Old 06-11-2025, 09:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Interesting flywheel.. have not seen that one before.. where is it from?
Always learning.
www.aircooledporsches.com.au
Old 06-11-2025, 11:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
proffighter's Avatar
Looks similar to my Fidanza
Roland
930 Turbo '81 Too many modifications to list
Old 06-12-2025, 05:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Thumbs up
Fidanza. I’m not sure where it’s from, I picked it up locally from Brian at euro parts west. 4.4 lbs I think.
how do you like it? Any feedback on performance?Also did you locktite the bearing to the fly wheel or leave it free to spin?
I did had take a little material off the lower case bolt boss to clear the rivets.
Old 06-12-2025, 06:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
I drove about 5'000km with, no issues since (400HP+). Use with KEP PP Stage1
It had no seat for bearing, made a aluminum adapter with press-seat for bearing.
No need to take-off material for mine.
Older pic, but shows enough
Roland
Old 06-13-2025, 05:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Another leak down.
Quick cold leak down, great numbers. All under 1%. Buttoning everything up, planning twin plug wire routings.
Old 06-16-2025, 09:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
A small cut out on the chain box is required to make room for the lower plug hole.
Old 06-16-2025, 09:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Thanks for sharing all the build updates - It's very much appreciated. This will be a great motor when you fire it up.
912E-3.2ss
Old 06-17-2025, 10:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
The tin is installed. I’m waiting for some twin plug pieces to arrive.
Old 06-17-2025, 06:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Thanks. I’m happy to share this build. I learn a lot from the forum participants.
Old 06-17-2025, 06:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
It’s always #2 / #5 big ends … cross drill the crank?
Old 06-18-2025, 12:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Good question.
That was my first thought, but after much research and consultation I’ve decided not to.
The decision to not cross-drill wasn’t about cost, time, or availability. There is a lot more to discuss but in short, it was about getting the right amount of oil to the right places. The 993 pump is more than sufficient and I don’t want to sacrifice oil to the top half of the engine.
Old 06-18-2025, 11:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Rosco_NZ
993 pump will be ample, as you say about getting the oil to the right place, if rods were correctly prepped, a spun bearing points hard in a particular direction no? Assume you plastiguaged and measured the oil clearance?
If there is a weak spot in the very robust 3.0/3.2 case, it seems to be 3/5 big ends….
I agree with taking care of the valve train .. perhaps don’t install the smaller restrictors ..?? With 993 pump you have plenty oil to share around. My own theory is that is top end restrictors were a reaction the bottom end oiling issue. Which is better taken care of with cross drilling.
Old 06-18-2025, 03:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
