What are the pro’s to Twin Plug Heads ? What sort of performance changes ? Any cons ? Do they work for 3.0 / 3.2 / or 3.4 ?
Simon _________________ 1982 911 SC Minerva Blue car from “Office Space”, 1944 Willys Jeep, 1977 TVR 2500M, 1973 VW Ghia Convertible, 1973 VW Thing, 1979 MGB. 1936 Panther 250cc, 1973 Yamaha DT 175cc |
@ Soko121 - there are other threads on this forum debating the benefits. I am no expert but basically twin plugs allow more complete combustion, allow higher compression engine on pump gas. You can also go coil on plug and avoid distributors and have a clean highly efficient set-up. There are a lot of pros and the biggest con is cost. Typically going twin plug would go along with higher compression pistons, ITBs, cams, porting heads. I'm in the middle of a twin plug 3.0 to 3.2SS conversion. Not cheap but definitely improved performance. TLDR: better performance and compression at the expense of cost.
Racer
Coil on Plug (CoP) works great on single plug setups...most CoP setups are single plug.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Location: behind the redwood curtain, (humboldt county) california
Craig Garrett did a great job on my 2.8
I think it is important to support our parts makers and machinist aficionados that do good work for our old cars.
Craig has good/prompt communication, excellent machine work, packaging and Good pricing. He sourced better quality guides, did a good valve job/head resurfacing and twin plug work for my dad's old 74. For sure, there are a lot of good people out there, and Craig is one of them. He took my 32mm intakes to 37. Use him again in a heart beat. chris |
FWIW I also had a great experience with Craig at G2.
I echo everything above. Chris in TX |
Craig Garrett (Cgarr)........excellent work, great turn time, pricing, etc.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
