2.7 motor low oil pressure
I have a twin plug hot rod motor in my 914 GT tribute. Less than 10,000 miles since rebuild and correct gauge and sender combo. Struggles to maintain one bar per 1000 rpm when warm. Recent leakdown showed 2% throughout the cylinders. It has a larger front oil cooler. Any thought that the extra cooler and oil line capacity might be too much for the oil pump? Trying to understand what is going on.
73 914-6 GT tribute, 2.7L twin plug 23 911 w/aero kit 07 GT3 RS Pumpkin |
My friends call me Phish
What's the current oil weight you are using, and is this first time you noticed this after 10k miles or did just start?
What's the pressure @ 5K?
3 bar
Rosco_NZ
44 psi hot doesn’t sound too bad. What oil pump? Updated pil pressure relief valves? Bypass mod?
It's a 914 ...
44 psi sounds a bit low, even for an early motor.
What are the oil temps? Higher temps could be a cause of lower pressure. |
You could install the cam tower oil hose restrictor fittings to get a bit more pressure. Not a big fan, but porsche designed them....
Is the 2.7 known for lower oil pressure readings?
Try not, Do or Do not
We still make our own fitting with a slightly larger oil passage and when we encounter the Porsche version we bore them out (slightly). The modification is a good one if you consider what your goals are.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
