Piston/cylinder question
Will the pistons/cylinders off an "85 Carrera fit my '82 SC. I'm going to be doing a rebuild soon and want the Nikasil cylinders, as opposed to my current Alusil ones.
I don't think there will be a problem but rather be safe ....
Old 07-16-2003, 10:17 AM
Bill Verburg's Avatar
The cylinders will fit fine but the wristpins are different 23mm for the Carrera 22mm for the SC, of course you could also swap con rods....but then you would need to swap crankshafts....
Bill Verburg
Old 07-16-2003, 02:54 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Short Stroke 3.2?
So does that mean I can buy 98mm cylinders, use 98mm JE pistons, and they will fit fine on my SC case and heads? I thought there was an issue w/ the cylinder to head sealing ring.
Wayne’s book says to use a 3.2 case w/ a SC crank for the short stoke 3.2. I’m confused.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 07-17-2003, 11:18 PM
S/S 3.2 is a 3 liter case w/ 70.4mm crank & 98mm p/c
L/S 3.2 is a stock Carrera w/ 74.4mm stroke & 95mm p/c
3.2 Carrera or 3.0 SC blocks are pretty much the same, there are minor differences like oil drain, the major difference between them is the crank, con rods and pistons(not counting ancillary sysytems like DME, alt etc)
Either block w/ 74.4mm crank & 98mm p/c is a 3.4 liter
Bill Verburg
Old 07-18-2003, 05:09 AM
Author of "101 Projects"
Wayne 962's Avatar
3.2 case and 3.0 case are basically identical. You need special 3.2 pistons that have the piston pin bore offset properly. I have the short stroke 3.2 RSR kit sitting right next to me. Cost is about $3500...
-Wayne
Old 07-18-2003, 06:34 PM
Wayne, you think you can keep that kit hidden for a couple months while I complete a 3.6 conversion and find a car for the 3.0??
What does that kit include, just P&Cs?
'81 911SC Targa 3.6
Old 07-18-2003, 07:24 PM
