Bird. It's the word...
2.7 Rebuild.... Advice?
Hello Gents
I finally splashed out on a 1974 2.7 CIS engine (currently very ugly). I've read all of Wayne's book as well as B.A's. Assuming I have Alusil barrels and the CIS pistons (and that I keep them for the time being), what is my best bet for extracting some power? On my list are S cams (BA recommends E cams). Can I use them with CIS pistons?. Webers, headers/sports exhaust (don't need heat here in Australia), and a dialed in distributor recurve. Will add hydraulic tensioners. What else is a good idea? Thanks ![]()
John Forcier Current: 68L 2.0 Hotrod - build underway |
Senior Member
That's great picture, John....to illustrate why *not* to paint the fan. They all look like that sooner or later.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Have good close look and see what the ham fisted morons did to get the motor out.... GAS AXE! They cut through the tinware and front mount
fishcop,
there's not enough clearance in the CIS pistons to clear S cams. If the engine is running ok then I might be tempted to run it as it is(with the new tensioners) and when the extra $$ is in hand swap pistons and cams and switch to webers.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Thanks Tim. I have a 2.0 in the car at the moment, so I won't bother putting it in the car until it's *right*. I have the webers, and a set of S cams, but you have cleared up my question on the P&Cs. Depending on whether I have Alusil or Nikasil, I will think about getting new pistons and rings right away (or should I re-use the current rings?). Do I have anything to gain from porting the heads whilst having the valves done at the shop?
I know there has been endless debate on the reuse of Alusil/rings and changing pistons, but until I pull the heads off I won't know what I have. Thanks
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Slumlord
Insert the head studs and helicoil the studs the studs in the case (but not the perimeter studs).
I just pulled three studs when I re-assembled my case, now I have to dis-assemble, heli-coil, and re-clean. ![]() 7R - German for two steps forward, one step back.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Yes Chris but did you notice the distributor cap looks really good!
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Given that I was really only chasing the long block, I'm not too concerned with the bolt-ons or injection system. Incidently I've found that the distributor is brand new... I guess that's one good score.
I've found only one pulled stud, but I do intend to time-cert the case on the rebuild.
No Expert
Fishcop,
Like everyone said, forget either the E or S cams with CIS pistons. It will never work. Totally inadequate valve to piston clearance. Hopefully you have Nikasil cylinders, but don't count on it. If the 2.7 engine was running when it was removed, you might want to try the webers on the long block as it is for a little while. It's a fun combination and will be an improvement over the CIS. It will have a ton more torque than your 2.0, but will not quite come alive over 4K RPM, like the S-cam engine will. Cracking the long block is a big commitment. You can always go back and do the full rebuild when the CIS core is used up. That's what I did, and I'm glad I did. Is your 2.7 from a 74-77 911S? If not, you will definitely want to port the heads, since the regular 74-77 911 heads have very small ports. Thanks,
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
Thanks for the advice JP. The engine did not come from a running car (arrived in a crate ex-Japan). But the crank and pistons turn over fine. Preliminary compression figures indicate it's sound. The main problem is that it was obviously subject to weather whilst stored, and when I shine a torch into the valve area a couple of the exhaust and intale valves appear to have light corrosion. So I think I'll have to have the top end done no matter what. Given that I don't know if the case leaks or not, I thought it might be best to just "start from scratch" as my car is running well on the 2.0
The engine is from a 1974 Japan delivery, so I'm guessing I have the small ports.
Slumlord
Is it from an "S"
Based on the color of the shroud, I don't think its an "S" engine. The "S" had a green shroud.
My $0.02. Troy
I always thought "S" motors had red shrouds.... All the S motors I have seen are red.... maybe just the pre 2.7 liter shrouds are red????
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 11-06-2003 at 02:17 PM.. |
I'm pretty sure that from 74 onwards, the colour of the shroud didn't tell you anything... I've measured my ports and I have the smallest made 30/33. Definitely need a head job.....
No Expert
I think the "S is red, E is green" rule is only true up to '73. My '76 911S had a black shroud. What is the engine type number? 911/92 or 93? Might be hard to see with the AC comprssor still on. I thought all of the ROW 2.7 engines had the larger 35mm ports. Guess not.
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S Last edited by jgparker; 11-06-2003 at 02:39 PM.. |
I found an actual reference to my engine in Wayne's book (spec. sheets at the back). I think the quote is "sometimes found with 30/33 ports"... Well I found them! I think I've found an engine with the most-least desirable parts
Well, all I can say then is my 75 is an "S" and it has a green shroud.
Troy
![]() Quote:
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Author of "101 Projects"
- Replate and use 2.7 JEs - S Cams - Valve job (maybe slight enlargement of ports) - Webers -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
