ischmitz's Avatar
Send a message via Skype™ to ischmitz
Cam timing mysteries - 3.6 engine
I finally got to the stage of timing my cams after some fellow board memebers went out of their way to help me with my rebuild. Without them I would be nowhere even close.
When I tried the factory timing method where you do the rough adjustment by getting the punch marks pointing up at Z1 and then do the fine adjustment by rotating engine until you get the specified lift at TDC overlap, remove the dowel pin - whoops there moves the cam when you pull the pin.
There is no way in hell that you can take the dowel pin out of the sprocket with the intake valve lifted (only intake #1 and #4 rockers installed) and not have the rocker rotate the cam out of position unless you use superglue!!!
With the mechanical chain tensioner adjusted tight the cam rotated even without the dowel pin in the sprocket when I rotated the crank. With loose tensioners the cam would slide out of position by the rocker acting on the lobe once I pulled the dowel pin.
The only way I got my timing done was to back away from TDC, make adjustments based on how far away Z1 was with the desired lift and then check with several rotations of the engine where I ended up. Once I got the hang of it the second side went much faster. One side ended up at 2.28mm and the other at 2.32mm lift at TDC overlap. Spec was 2.2 - 2.4mm
Next weekend is final assembly time and hopefully first light.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-02-2004, 03:30 PM
If all the rockers are in the cam won't move.
Pete
Old 02-03-2004, 06:55 AM
Super Moderator
cstreit's Avatar
Pete is right...
...it will sometimes still move but not very often...
...and the factory cam holding tool will prevent it...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-03-2004, 08:29 AM
Author of "101 Projects"
Wayne 962's Avatar
Right - as Jerry Woods told me, it's nearly impossible to do the cam timing on these engines without using the factory camshaft holding tools.
Hmm, I guess I need to get started on that 3.6 supplement...
-Wayne
Old 02-03-2004, 12:32 PM
ischmitz's Avatar
Wayne,
you are talking about the 993 cams here. How many 3.6's have you rebuild so far? That's another story altogether. On the 964 there is nothing where you can hold the left cam. The cam tower has a plug at the flwheel end.
It makes sense that the cam hardly moves with all rockers installed during timing since at overlap exhaust and intake rocker push into oposing directions onto the cam shaft.
Ingo
Old 02-04-2004, 10:22 PM
Irrationally exuberant
ChrisBennet's Avatar
Originally posted by ischmitz
Wayne,
Ingo
I think I'm missing something here. Am I having another "Senior Moment"? Why can't I hold the 964 cam still the same way I do for a 3.2? Except for the cars that had pump drives (930's, MFI, 3.6 w/pwr steering) cam towers are usually plugged at the flywheel end anyway.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-05-2004, 01:10 PM
ischmitz's Avatar
From what I know the 993 cam towers are open on both ends. The have a couple of threaded holes in the cams where the Porsche cam holding tool attaches.
The 964 with PS are open on the left side but the cams don't have the same threaded holes.
Ingo
Old 02-05-2004, 10:06 PM
Ingo,
I see the source of the confusion now. I'm not familiar with the 993 setup but it sounds different than the earlier motors. The late 3.0, 3.2 and 3.6 (964) cams have a bolt in the end of the cam that you can use to turn the cam, and the sprocket has holes that you can use to hold the sprocket with using the 9191 tool.
-Chris
Old 02-06-2004, 07:14 AM
Bill Verburg's Avatar
Here's pic of how it was done on my 993 w/ backdated 964 cam sprockets
The hydraulic lifters require either the factory tools or temporary replacement of the hyd lifters on #1 w/ mechanicals for cam timing purposes.
Bill Verburg
Old 02-06-2004, 11:54 AM
LOOK AT THE SIZE OF THOSE INTAKE PORTS! AWSOME! Also appears that each port requires 3 bolts to hold intake securely to them. Wonder what these heads would do with forced induction?
Old 02-10-2004, 08:33 PM
Super Moderator
cstreit's Avatar
You sure got a purty motor there.
I promise to take care of it for you Bill, I'll even pay 1/2 of shipping!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-10-2004, 09:13 PM
Yeah, the ports and valves are pretty big
The last thing a fly sees after it gets past a cone flter
The last thing super fly sees on his way back out
Bill Verburg
Old 02-11-2004, 12:40 PM
