mackpipes
Guest
Posts: n/a
upgraded valve springs
I'm rebuilding my euro 3.2 and beefing up everything with raceware head studs as well as raceware rod bolts. I want to use stiffer than stock valve springs and ti retainers for some over-rev insurance. My question is this:
Who would you recommend for upgraded valve springs and retainers?
I will be using stock cams. The car will be used for both DE and street. Thanks in advance.
Old 02-09-2004, 10:33 AM
No Expert
jgparker's Avatar
EBS Racing. The sell racing springs and Titanium retainers.
http://www.ebsracing.com/
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 02-09-2004, 10:57 AM
mackpipes
Guest
Posts: n/a
Would you chose their springs over Jerry Woods or Competition Engineering, or are all aftermarket upgraded spring pretty much the same?
Old 02-09-2004, 11:35 AM
Irrationally exuberant
ChrisBennet's Avatar
I went with the AASCO springs. You will need to have the spring seats/cups machined (very easy job) to fit the springs. Jerry Wood's may include new seats which would save you a step.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-09-2004, 01:10 PM
Anyone know the specs on these aftermarket springs?
Thanks in advance.
Sherwood
Old 02-09-2004, 03:16 PM
You do not have permissi
john70t's Avatar
As usual clean and check even new parts.
Old 02-09-2004, 05:58 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I'm also looking for replacement springs....and would like to use Vasco-Jet if possible.
I know they are expensive (not much more) than stock springs...but they last forever and 3 days.
We used to use them in drag engines, and would re-use them for years.
Bob
Bob Hutson
Old 02-09-2004, 06:15 PM
Bill Verburg's Avatar
Smart Racing
Valve Spring Kit: Springs, Retainers,
and Bases (Our valve spring kit can be used with
stock retainers - for production club racing.)
• 8000 RPM safely with STOCK rocker arms.
• Approximately 120 LBS of seat pressure with .500" lift cam.
• Many years of race proven experience and testing
• A must for ANY engine, street or race.
• Install some insurance from costly overrevs.
911 9 mm valve (Set of 12) . . . 134100 . . . $550.00
911 8 mm valve (Set of 12) . . . 134200 . . . $550.00
Bill Verburg
Old 02-09-2004, 06:59 PM
Super Moderator
cstreit's Avatar
Wonder what the difference between the EBS VMAX and Smart Racing springs are?
I know EBS uses a coated spring and xray's 'em... I'm using them, they still work after one season, so far, so good.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-09-2004, 07:27 PM
EBS sems to be big into coatings(as are quite a few other tuners), anything can be coated and it does work. I suspect but have no proof that most spring kits are supplied form only a few ultimate sources.
Bill Verburg
Old 02-09-2004, 07:38 PM
Since Smart Racing is associated with Jerry Woods, one might assume that the Smart Racing springs = Jerry Woods springs.
The AASCO springs I have look kinda bluish if I remember correctly. Probably some sort of coating.
-Chris
Old 02-09-2004, 07:43 PM
