Ho Hum 74's Avatar
Case plugs: Ok to tap and use threaded plugs?
Hi all,
Since I can't find anyone who can sell me the two case plugs my machine shop removed to clean the case, is it ok to tap the holes in the case and use a threaded insert? Anyone done this before? Seems to make perfect sense to me. Any drawbacks?
Tristan
Old 02-21-2004, 11:00 AM
Irrationally exuberant
ChrisBennet's Avatar
Normally a machine shop would just make new plugs from some aluminum stock.
The first time I had the machine shop clean the case in their tank; remove the plugs, clean the galleries and make new plugs. They didn't have the aluminum for the plugs so I supplied some.
The 2nd time (different machine shop) I had threaded plugs put in. They machine shop had to modify the plugs do the wouldn't stick too far into the passages.
If you are using a shop that is unfamiliar with Porsches, specify which plugs to remove.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-21-2004, 12:17 PM
Ho Hum 74's Avatar
Thanks all.
Old 02-22-2004, 02:03 PM
