Need some suggestions...I've been working for two days trying to get the cam nuts broke loose. No luck. I've got the 46mm crowsfoot and the other cam tool, using a 2 ft. breaker bar and a 3 ft. piece of pipe for leverage on both. Still no luck.
Any suggestions as to how to get these loose? I don't have access to an impact wrench.
Dan '68 911L w/RSR Gruppe 'B' Bastard Factor 1856 |
Not sure what to suggest at this point really.
I am in Orange County, (as a last resort) your more than welcome to cart that engine up here and I could zip it off for you... Chris
Chris Walrod 1997 993tt |
Hi Dan:
No easy answer here, I'm afraid....you either need: 1) More leverage (longer bars) 2) A good air-operated impact gun 3 ) C-4 (effective, but not recommended except as a last resort) Chris's offer is lookin' real good,..... ![]()
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
If you don't want to cart the whole motor to someone you could break the motor down to the cam carrier+chainbox. Any of your buddies have a nitrogen tank and an air gun you can borrow?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i Coupe http://members.rennlist.org/messinwith911s/ |
Sounds like it is time to buy an electric impact wrench.
72 911 Targa VTK Member 110245 71 911 Targa 68 911 non sunroof Coupe Gruppe B # 3911 http://www.pelicanparts.com/gallery/cassidyp |
Anybody see any problem with heating the nut with propane to expand it thus reducing the torque he has to overcome?
77 911, 3.0L |
Who is John Galt?
I think heat is a good idea. I would also think about knocking on a corner of the nut with a cold chisel to try to loosen it up.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
SCWDP President
E-Z....just find your local tool rental joint, and rent a beefy Milwaukee™ electric impact wrench. (No....ugh....cold chisels please).
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Thanks for all the input. I'll try the heat first since I have a torch, then the impact hammer (mechanic shop at work) then the C4 as Steve suggested (last resort...this may put the garage back into original condition before I started the P-project...haha)
I would not use impact. I take a breaker bar w the Cam socket and wedge against the motor mount studs. then w another breaker bar crack the 46mm nuts loose. works every time no heat, no impact
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
I've already tried that with 4' bars, only thing that happens is the crowsfoot springs open and spins off the nut. Total result...3 scraped knuckles and a pulled back muscle.
I'll try the heat tomorrow.
Super Moderator
Be careful not to get too much heat on the aluminum chain housing or the thin alum. thrust plate behind it!
Chris Streit ---------------------------------------------- NASA GTS series Director - Midwest Partner - ProRaceSupply Motorsports Commerce Owner of MotoDelta Motorsports and AlconKits.com 2001 GT3 Cup - "Pepin" 1996 993 RS Replica"Polly" 1970 911 NASA GTS4 - PCA GT3 class "Phoebe" FOR SALE 1997 Ducati 748 Monoposto "Daphne" 1971 Norton 750 Commando |
are you using the official porsche crowsfoot? It's a really beefy tool. There's a few 46mm crowsfoot wrenches that will just bend under 200ft-lbs of torque
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Banned from Pelican
YOu need the proper tools to do any job. In this case the proper tool is an air impact wrench, period.
Has the engine been apart before?
I've heard some folks use loctite on these threads for 'good measure'. Heat up the threads to break any bonding material (if any) and try again. A 4' breaker SHOULD get it off.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I'll use a soldering torch for plumbing that I have, that way there isn't as much heat as a regular torch. Thanks for the advice on the aluminum, Chris. Tim, I've got a 46 mm from sears, Pelican still has theirs on backorder, (3 weeks now). Impact wrench next option. Charlie, as far as I know from talking to the PO, the cams were upgraded to RS versions, and mechanical tensioners were installed. No knowledge on P&C's or the case. That's why I've decided to go all the way down to bare case and start over.
If you heat it up take a piece of candle wax and let it melt into the threads, for some reason this helps to loosen things up.
Works great on cast iron blocks with oil line plugs etc, but im not sure a propane torch will get it hot enough. good luck
John Dougherty Dougherty Racing Cams |
Banned from Pelican
Breaking the bond, it it is locktite, requires more heat than any porpane torch can do. At the min MAP gas is required.
Well, so far heat from MAP gas, candle wax, long breaker bars, and......No luck.
Next step impact wrench at work, then......C-4 as suggested I will accomplish this mission, I will, I will, I will ![]()
Try Sir tools for the 46mm crows foot. That probably where Pelican gets them from.
