Angry Cam Nut removal options???
Need some suggestions...I've been working for two days trying to get the cam nuts broke loose. No luck. I've got the 46mm crowsfoot and the other cam tool, using a 2 ft. breaker bar and a 3 ft. piece of pipe for leverage on both. Still no luck.
Any suggestions as to how to get these loose? I don't have access to an impact wrench.
Dan
'68 911L w/RSR
Gruppe 'B' Bastard Factor 1856
Old 03-20-2004, 09:13 PM
Not sure what to suggest at this point really.
I am in Orange County, (as a last resort) your more than welcome to cart that engine up here and I could zip it off for you...
Chris
Old 03-20-2004, 09:46 PM
Hi Dan:
No easy answer here, I'm afraid....you either need:
1) More leverage (longer bars)
2) A good air-operated impact gun
3 ) C-4 (effective, but not recommended except as a last resort)
Chris's offer is lookin' real good,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-20-2004, 09:54 PM
Irrationally exuberant
ChrisBennet's Avatar
If you don't want to cart the whole motor to someone you could break the motor down to the cam carrier+chainbox. Any of your buddies have a nitrogen tank and an air gun you can borrow?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-21-2004, 04:20 AM
cassidyp's Avatar
Sounds like it is time to buy an electric impact wrench.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 03-21-2004, 04:38 AM
Doug Steinel's Avatar
Anybody see any problem with heating the nut with propane to expand it thus reducing the torque he has to overcome?
77 911, 3.0L
Old 03-21-2004, 05:28 AM
Who is John Galt?
Rondinone's Avatar
I think heat is a good idea. I would also think about knocking on a corner of the nut with a cold chisel to try to loosen it up.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 03-21-2004, 06:30 AM
Senior Member
Doug Zielke's Avatar
E-Z....just find your local tool rental joint, and rent a beefy Milwaukee™ electric impact wrench. (No....ugh....cold chisels please).
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 03-21-2004, 07:02 AM
Thanks for all the input. I'll try the heat first since I have a torch, then the impact hammer (mechanic shop at work) then the C4 as Steve suggested (last resort...this may put the garage back into original condition before I started the P-project...haha)
Dan
'68 911L w/RSR
Old 03-21-2004, 08:56 PM
126coupe's Avatar
I would not use impact. I take a breaker bar w the Cam socket and wedge against the motor mount studs. then w another breaker bar crack the 46mm nuts loose. works every time no heat, no impact
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-22-2004, 09:48 AM
I've already tried that with 4' bars, only thing that happens is the crowsfoot springs open and spins off the nut. Total result...3 scraped knuckles and a pulled back muscle.
I'll try the heat tomorrow.
Dan
'68 911L w/RSR
Old 03-22-2004, 05:55 PM
Super Moderator
cstreit's Avatar
Be careful not to get too much heat on the aluminum chain housing or the thin alum. thrust plate behind it!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-22-2004, 06:03 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
are you using the official porsche crowsfoot? It's a really beefy tool. There's a few 46mm crowsfoot wrenches that will just bend under 200ft-lbs of torque
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-22-2004, 06:05 PM
Banned
snowman's Avatar
YOu need the proper tools to do any job. In this case the proper tool is an air impact wrench, period.
Old 03-22-2004, 11:27 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Has the engine been apart before?
I've heard some folks use loctite on these threads for 'good measure'.
Heat up the threads to break any bonding material (if any) and try again. A 4' breaker SHOULD get it off.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 03-23-2004, 09:58 AM
I'll use a soldering torch for plumbing that I have, that way there isn't as much heat as a regular torch. Thanks for the advice on the aluminum, Chris. Tim, I've got a 46 mm from sears, Pelican still has theirs on backorder, (3 weeks now). Impact wrench next option. Charlie, as far as I know from talking to the PO, the cams were upgraded to RS versions, and mechanical tensioners were installed. No knowledge on P&C's or the case. That's why I've decided to go all the way down to bare case and start over.
Dan
'68 911L w/RSR
Old 03-24-2004, 10:31 AM
camgrinder's Avatar
If you heat it up take a piece of candle wax and let it melt into the threads, for some reason this helps to loosen things up.
Works great on cast iron blocks with oil line plugs etc, but im not sure a propane torch
will get it hot enough.
good luck
John Dougherty
Dougherty Racing Cams
Old 03-24-2004, 08:52 PM
Banned
snowman's Avatar
Breaking the bond, it it is locktite, requires more heat than any porpane torch can do. At the min MAP gas is required.
Old 03-24-2004, 09:58 PM
Angry Stupid cam nuts
Well, so far heat from MAP gas, candle wax, long breaker bars, and......No luck.
Next step impact wrench at work, then......C-4 as suggested
I will accomplish this mission, I will, I will, I will
Dan
'68 911L w/RSR
Old 03-26-2004, 06:54 PM
wrongwaywayne's Avatar
Try Sir tools for the 46mm crows foot. That probably where Pelican gets them from.
Old 03-26-2004, 07:36 PM
