Main Jets size for 3.0 Twinplug w/40 Webers?
What size main jets should I use with my 1973 slightly modified 3.0 twinplug engine. I have 40mm Weber intake with MoTech ignition. It doesn't seem to have power at higher RPM, I just pulled out the main jets and they're only 110's.
On the street I use a Sport exhaust (two in, two out with very little packing) ... but on the track I'm using open exhaust and it seems really lean. My friend has a 3.0 single plug with 40mm webers and bosch and he's running 160 main jets.
What size main jet should I use? Thanks for any advice you have!
Old 05-10-2004, 02:30 PM
No Expert
jgparker's Avatar
Wow, that is small. The set-up may be for a much smaller engine. I'm running 180 mains on my 2.8. Also very important, what venturies are you running? 36 or larger I hope? I got my carb set-up advice from Richard Parr at PMO. The man knows his stuff, and can sell you all the Weber/PMO parts. I don't believe Pelican sells carb set-ups.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-10-2004, 02:46 PM
Author of "101 Projects"
Wayne 962's Avatar
We sell all of Richard's (PMO) stuff here. It's somewhere in the catalog - try the search engine.
As for jetting, you'll constantly be guessing without a dyno, or one of these Digital Air/Fuel Ratio Meters:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_fuelCI_pg14.htm#item51
-Wayne
Old 05-10-2004, 04:52 PM
No Expert
jgparker's Avatar
Woops, I do try to get everything I can from Pelican. I couldn't find Weber jets or venturies in the search engine.
I double checked my 2.8 when I got home, and I ended up with 160 mains, not 180s. I can't find a recomended starting point for a 3.0 in any of the PMO instructions, but I'm sure there is someone on this board who can recomend one.
Is that "the corkscrew" on your Avatar?
Good luck,
JP
Old 05-10-2004, 05:58 PM
rs911t's Avatar
Good. I was about to chime in about that. You probably have 180 air correction jets. That's what I run on my 2.8, but I'm only running 155 mains. Thought about 160s, but haven't put the AFR meter to it yet.
Greg
Old 05-10-2004, 08:01 PM
gumba's Avatar
I dynoed my 2.8 twin plug yesterday. I'm currently using 150 mains, 36mm chokes. 140 air correctors. It's running rich from 4000 - 5600 rpm. I figure I will have to go up in air correctors. Has anyone used the digital air/fuel ration meter Wayne mentions?
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 05-11-2004, 08:38 AM
jluetjen's Avatar
Did anyone ever say what sort of venturi's they were using? Because all the rest of the jetting will depend on which venturi you use.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-11-2004, 08:47 AM
Thanks guys for all the helpful information. I think the best thing to get maximum performance is to get it on a dyno.
JP - Yes, that is the corkscrew.
Old 05-11-2004, 08:54 AM
No Expert
jgparker's Avatar
Does anyone know if there is a sniffer version of a Air/Fuel Ratio Meter available? I'd rather not weld bungs into my exhaust systms.
Thanks,
JP
Old 05-27-2004, 01:45 PM
Wayne 962's Avatar
Yes, this unit does that. You simply get the bracket that attaches this to the tailpipe - that's what I do. It gives very accurate readings (drove around with it for a long time on my truck and 308).
-Wayne
Old 05-27-2004, 02:04 PM
You can't compare main jet sizes unless you are using the same venturi size and the same emulsion tubes. The three combined (along with a lesser extent air correctors) adjust your main fueling.
Matt B
'73 911E
Old 05-30-2004, 08:35 AM
I would also ask what cams you have and what your compression ratio is?
Both play a big role in jetting selections.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-30-2004, 04:33 PM
