WydRyd's Avatar
Boring from 955mm to 98mm
Hi Gang,
I have a set of 95mm Mahle cylinders out of my 3.2 Carrera.
I'm thinking of having these bored out to 98mm, Nikasil coated and having a set of JE Forged Turbo Pistons made up for them @ 7.5-8.0:1 C/R.
Does anyone know who specialises in this type of machining?
Is it worth doing? Any problems in doing this?
I'd like to think that Nikasil coating them will make them more durable and I heard from somewhere that this is what Mahle/Andial do anyway (bore 95mm cylinders to 98mm's).
Can anyone clarify this?
Thanks in advance
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-11-2004, 01:47 AM
PJMARKOW's Avatar
Electosil in Melbourne will bore and plate those cylinder for you.
Their web site's at www.electrosil.com.au I've just sent my pistons and cylinders there.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 05-11-2004, 03:34 AM
WydRyd's Avatar
Thanks Paul!
Can you give me some idea of what I'd be looking at to have mine bored and replated?
Did they give you some idea of turn-around time for these?
Are you having yours Electrolubed as well?
Merv
'89 911 Turbo Cab
Old 05-11-2004, 05:43 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Hi,
I don't know what Mahle does in Germany, but unless things have changed (I really doubt it) in the last 10 years since I worked at Andial the cylinders are not bored by Andial from 95 to 98.
We used to get them from Mahle as complete sets ready to install, there wasn't any work to do to the cylinders. If the set was for a 3.4L or 3.5L 930, I remember we used to modify (i.e. flat dome) the 98mm or 100mm Mahle Motronic piston to lower the CR to the 7 or 7.5 range. There was also additional modifications done to the 100mm piston to make a 3.3 to 3.6L using the than new 964 crank.
Not sure if I answered your question?
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 05-11-2004, 12:49 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
if you can bore them out and recoat them with nikasil, can you also do that with alusil barrels? is it something deeper in the metal or is it just the finish? anyone have a cost estimate stateside for the recoat?
thanks
doug
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 05-11-2004, 03:20 PM
WydRyd's Avatar
PaulM, I received a reply from the Electrosil mob and they are just WAY too expensive!
I can get my 95mm Liners bored out and replated in Nikasil for $900USD by EBSRacing.
Electrosil quoted me $435 PER CYLINDER for boring and plating
Merv
'89 911 Turbo Cab
Old 05-11-2004, 04:35 PM
No Expert
jgparker's Avatar
Yes, EBS can bore Alusil jugs and reprocess them to Nikasil. I think it is around $150 per cylinder.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-11-2004, 05:34 PM
Bird. It's the word...
Fishcop's Avatar
Merv, I went through this late last year. I ended up buying new P&C from Pelican and having them shipped taxes and all.
If you go through EBS, contact a customs broker first as there is a shyte load of paperwork to ensure your ability to prove the originals you send over are the same ones coming back after repair. Otherwise the nice new shiny rebuilt set will confuse the poor customs dog and you will be charged customs on new items, rather than no charge for "repaired" items.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-11-2004, 06:00 PM
Just to follow up on the Mahle reboring issue, I checked at home and still have my notes for all of the Mahle internal piston and cylinder part numbers.
Same cylinders are used by Mahle (i guess rebored if 98's) for the following sets:
3.2L from 3.0L - CIS
3.2L from 3.0L - Carb
3.4L from 3.2L - Motronic
3.2L from 3.0L - Turbo
3.4L from 3.3L - Turbo
I guess that is why some Porsche engine builders feel that 100mm cylinders are stronger than 98's, because 98's apparently are 95's that have been rebored and thus are a bit thinner.
Was that of any use to you?
Ralph
Old 05-11-2004, 09:04 PM
WydRyd's Avatar
Actually, looks like Electrosil came to the party and have offered to do mine for a total of AUD$1500 (that's bore and re-coat), which includes a 6 month Guarantee on the coating
Not sure what advantage I'll have going from 3.3L to 3.4L anyway (3% capacity increase), so might just be worth selling my 95mm P&C's as a set and just sticking the 930/97mm's I have in there.
Thanks gang
Merv
'89 911 Turbo Cab
Old 05-11-2004, 11:24 PM
PJMARKOW's Avatar
Hi Merv,
That $1500 price is more like it. I think my quote was about that. As for Electrolube, I think it's included in their composite coating. You can check the technical description on their web site.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 05-12-2004, 03:56 AM
PJMARKOW's Avatar
Hi Merv,
Do you have a copy of the email from Electrosil with teir revised quote?
I don't have my original quote, and now they are quoting $380 a cylinder just for replating
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 05-13-2004, 12:34 PM
WydRyd's Avatar
Paul,
I'll forward it to you from my Work e-mail address.
Stay tuned...
Merv
'89 911 Turbo Cab
Old 05-13-2004, 03:21 PM
