Yet another reminder that the need for twin plug conversions is highly overrated.
Author of "101 Projects"
Since you referenced the Ferrari, when they went to CIS, the HP dropped by about 20% due to the lack of performance of the CIS cams and system. That is why I specifically bought a carbureted version with independent throttle boddies. Likewise, the 911SC engine produces 180 HP, compared to the 210 of the MFI RS motor that proceeded it. This is even despite the low compression of the stock RS engine, and the increased displacement of the 3.0L. Yes, you can increase displacement to overcome and overcompensate for any handicap with the CIS system. CIS is old technology (1970s), it doesn't perform pulsed metering, requires intake plenums and sensor plates that are affected by fuel reversion, and thus, you can only use relatively mild camshafts with them. Heck, the early CIS systems weren't even closed loop (exhaust gas sensor) systems. As for an agressive cam in a 3.4 motor - it would be very driveable on the street, with gobs of low end torque. As I discuss in Chapter Four of my book, the increase in displacement eases the low-end torque problem that is common in motors like the early 'S' 2.0. CIS is a good, reliable system that produces less emissions, and enables cars to pass smog tests. If building a big bore, high performance engine, it would not be at the top of my list. A fuel system that would supply individual throttle boddies would be first (TWM EFI, MFI, carbs). Then would come the closed-loop Motronic system with the common plenum. Then would be CIS. Sorry to have offended you... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
"First of all, I have a 914-6 with a 3.2, and have written two books on Porsche 911s, so I would guess that I know what I'm talking about"
You're kidding me right? Ok, but I wasn't offended. Guess you missed the smiley face. I never claimed that CIS was a performance induction, just a reliable one, made for passing emissions and cheap for those of us with CIS cars. I could have used any induction I wanted. For now I wanted CIS for no other reason than to put CIS into perspective. I'll let the guys who drive my car make up their own minds. There were so many changes beside the MFI (still one of the best induction sysetms available for HP) between '74 and '78 that your 210/180 comparison is moot. More so when you do a little work on CIS (exhaust and cam which still make emissions) and get 215. Dane |
CIS CIS CIS, its great dont get me wrong, fires up in the morning without complaints, runs nicely throughout the day, emissions well those are decent i suspect. I have a 78 3.0 SC with the CIS and SSI's and also 20/21 cams. The engine makes very good power but I just cant wait to go wilder on the cams change to MFI and move up a little in displacement.
Hey wayne, I drive a jetta only because dad made the porsche his daily driver, I love hucking that thing around all the ricers here in pasadena, I just love the look on their faces.
74 911s neverending story. two feet and a jetta for now. |
quick question here. this summer my dad and i are rebuilding the engine with the max moritz kit but have decided on higher comp. pistons. as long as the engine is apart is it worth the extra money to throw in a 3.2 crank and rods to make it a 3.4??
Yes, the crank and rods are worth every penny and then some IMO. I'll have a dyno posted in the next few weeks to give you an idea of what is possible from CIS and a 3.4. The driving experience in unbelievable to this point. Helmet Bott ran a 3.5 for many years in his personal car. My response when asked is, "almost, scary fast" for my 3.4 CIS. My mileage has gone up BTW and not down, even the harsh way I have been driving it on breakin. Quote:
Hook up with Andial and beg a ride in one of their CIS big bore cars. That will answer a lot for you I suspect. Last edited by rdane; 05-25-2004 at 11:37 PM.. |
- The two motors basically share the same crankshaft. - The two cases are very similar, except that one is aluminum and one is magnesium (doesn't affect power). - The pistons on the RS are shaped with higher domes to work with the 'S' camshaft. The 3.0 pistons are specifically shaped to work with the mild-profile CIS camshaft. Both engines had 8.5: compression - The Euro Carrera was a 3.0L displacement, the RS engine was a 2.7 displacement - The Euro Carrera had much bigger ports than the RS engine (39/35 vs. 36/35) - They had the same sized valves Looking at the specs for the Carrera 3.0, you'd think that the larger ports and larger displacement would generate an engine with significantly more power. Yet power per liter was down significantly from the previous year's system due to the switch to CIS and the mild CIS cam. As I mentioned previously, the same thing happened to the Ferraris when they made a similar move to CIS - power was significantly down. For an idea of what the 911SC could have been had it been sold with MFI, you have to look at the 911SCRS with 255 HP (although arguably, in a street car it would be lower, as you would want to drop the compression from 10.3:1 to about 9.8:1). A good individual throttle-body EFI system should be able to achieve at least that, if not more, using closed-loop monitoring of the mixture. CIS is a very reliable, simple system that is good for emissions and everyday driving. I'm not knocking it - I'm simply saying that the other systems deliver better performance. I can't say for sure, but I would guess that the reason why Andial builds so many CIS big bore engines is so that they will pass smog. A friend of mine bought their experimental 3.7 CIS engine a few years ago (Steve Lee). I believe that car was left with the CIS system on it soley to avoid smog problems. I suppose if I were going to spend a lot of money on a big bore upgrade, I would probably want to go with an EFI system to extract the maximum HP per dollar. However, if you're trying to keep the car smog legal, I can certainly see a very good argument for keeping and tweaking the existing CIS system. -Wayne
Fair enough, how about this? '74 2.7 MFI @ 210hp @ 6300k and 255@4500 '83 3.0 CIS @ 204hp @ 5900k and 267@4300 The 3.0 CIS SC ran at lower revs, with more torque, had a longer engine life by far, certainly was/is more reliable and passed some pretty strict emmissions. Now add to that data a '78 or '79 with a good CIS cam and a set of SSIs makes 215hp no problem (with the same lower 8.5:1 compression), as many Pelicanites can atest. This while getting some of the best mileage seen in a 911 to date in '83. All things I really value in a street car. I would hope any modern EFI system would better all of that. But at what cost? You have discouraged a 3.2 crank @ $1500 as too expensive, but figure a EFI @ $1500 plus labor is a good investment? No one is going to argue "there is no replacement for displacement" here, right? CIS isn't the best performance induction available today or yesterday. We both agree on that. But from my many phone conversations with Pete and Deiter @ Andial, I was under the impression that they used CIS and Motronic for convenience, price and a nod to emissions, in that order. If CIS or Motronic were so limited I doubt they would have built as many performance engines with either induction. Your points are well taken Wayne, I just don't agree with all your conclusions. But that is what makes a horse race, eh? |
This is sortof a silly argument, because on some level, we're both agreeing with each other.
"convenience, price and a nod to emissions, in that order. " Nowhere in that sentence is the word "performance", which was my original statement and point here. Just to refresh: Quote:
You did touch on a good point with the cost of an EFI system versus a 3.2 crankshaft. It's personal preference there. I would rather have an EFI system on a 3.2 than a CIS system on a 3.4 with a Carrera crank. In my opinion, the EFI system allows you a lot more freedom and flexibility, and also allows you to grow with the engine as you make changes. I'm a big fan of EFI... -Wayne
Let me add another thing - my whole argument against CIS (and Motronic too) is that they are throttle-body induction systems. In order to run a more aggressive cam, you need to have individual throttle boddies, like on the MFI system or Weber carbs.
However, I'm not a huge fan of simply bolting carburetors onto a CIS engine. You will get poor gas mileage, an emissions nightmare, and decreased performance, overall. You may get a bit better throttle response, but it's at a high price. The only time I really advocate ditching the CIS system and bolting on carburetors is if you're going to swap out your camshafts. -Wayne
Henry......For the 100mm cylinders are you boring the spigots on the case.......and if so how are you sealing tha case? "O-ringing" the spigot bores by cutting a groove in the bore perhaps?
'77 930 "proponent of positive manifold pressure" |
Licensed User
If I get into my 3.whateveritis and find the 100mm Mahles, I may spring for a 74mm crank and try something similar. Also Henry, does your shop do the custom MFI setups? Thanks Henry! Last edited by Shuie; 05-28-2004 at 10:37 AM.. |
Try not, Do or Do not
Yes, SUPERTEC builds custom MFI systems
Services offered by SUPERTEC
Bosch MFI MFI throttle housing rebuild MFI pump rebuild Custom MFI stacks Custom MFI injector lines Supertec hand choke assemblies New and used parts Bosch ignition distributor Overhaul Recurving Pointless conversions New and used parts Twin plug conversion Bosch CIS Rebuild fuel distributor Rebuild warm up regulators Custom made fuel lines ( high pressure Parflex , 1100 lb burst pressure 500 lb operating pressure) New and used parts Head work Valve jobs Porting Twin plug Engine rebuilding ( 911/930 air cooled only ) Stock Hi performance Transmission Rebuilding Stock Special application Vintage racing, V8 conversions Special ratios Transmission Parts Over 150 Porsche Transmissions in stock 901, 912, 911, 915, 931, 930 All stock ratios on the shelf Main shafts, R&P, nose cones, cases, side covers and speedo drives. Differential housing by the dozens. Supertec Performance exclusive products Supertec head stud kits (State of the art aerospace design) 930 Turbo Carbon fiber air filter assemblies (30% increase CFM and increase ease of maintenance Cylinder head spacer for 2.2 to 2.0 head conversion (Allows for big valve heads to be installed on 2.0-liter cylinders) Differential ring gear spacer (Late limited slip in early box) Cylinder spigot reducers (Restore early cases to original spigot size, or turn 7R case into 2.0 – 2.4 spigot size)
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-28-2004 at 12:51 PM.. |
Henry....
How about a group buy those 3.5 MFI engines! That sounds just incredible.... but im not sure my 901 could deal with it!
Terry |
Terry:
We were told for YEARS that our 915s couldn't handle the 350+ hp we run through them. It has been 10+ years on multiple versions of twin-plugged 3.0L, 3.2L, 3.4L and 3.5L engines and the 915 box has NEVER been the problem. Reading between the lines ... something else usually happens (race "rubbin", missed shifts, major and minor shunts, etc...) Currently running 220+ hp through a 901 in a '68 2.0L ... no problems. Jason |
John (Otto) has run 901s with 300 horses through them for ages. I think he reinforces the center plate though...
-Wayne
Anyone have any thoughts on a short stroke 3.8 ? Using a 3.6 case modified to take 102mm pistons and a 3.2 crank which has a shorter stroke than the 3.6. The thinking is a higher reving version of a 3.8. I know special pistons would have to be made, but does anyone think it is worth it or should I just use a 3.6 crank ?
Shorter is better, at least that's what I tell my girlfriend.
I like any thinking that leans towards shorter stroke 911s. I think a better way to go would be to destroke and lighten (knife edge) the 3.6 crank. This would require a custom rod but it is my opinion that the 3.2 crank and rod combo sucks, and the 3.6 rod is too short. By destroking the 3.6 you get a smaller ( less friction) rod journal and larger radius at the flyweight for great stability ( more strength). By using the stock 3.6 wrist pin location in the 3.8 piston the rod gets longer and the engine gets happier. Why? Because the rod length to stroke ratio gets better ( less rod angularity = less piston side loading ). It is also my understanding that cylinder filling is improved when a piston spends more time at TDC and this time is lengthened by smaller rod angles.
Re: Shorter is better, at least that's what I tell my girlfriend.
Henry, I have a specific question I'd like your opinion on, and that of anyone else interested: 3.0s can be built relatively easily in a couple of different configurations: 1. 70.4x95 (SC, 3.0 Carrera, 3.0RS, 3.0RSR) 2. 66x98 (bigger bore version of short stroke 2.8) Note that the 3.0RSR made peak power at 8000rpm, with max. engine speed slightly above that. I don't think the factory was using any 98mm cylinders at the time, so #2 might not have been obvious. Here's my question: If you built a #2 configuration race engine, what power peak RPM (or torque peak, whatever you prefer) would you be shooting for? would you try to use bigger cams to lift the power peak over 8000 rpm, perhaps 8500? My point is, if the power peak is not any higher than 8000 or so as in the RSR, at least in a 3.0 it would probably make sense to use the #1 configuration, not least because it is much easier to create. I make no statements about the 3.2/3.6 since they have quite a longer stroke. However, even longer stroke 911 engines are still very oversquare compared to many production engines. As an example, the original honda S2000 engine has an 84mm stroke, and a 9000 redline. No doubt the reciprocating assemblies are lighter (have you seen a honda rod lately), but I'm curious where the balance point is in 911 engines between stroke and comfortable RPM. TIA
Andy |
