Thats it, I am done. I am not going to get into a pissing contest. Take it for what it was worth, just trying to lend some advice on how to do the job properly.
Try not, Do or Do not
Hi Christian There are all forms of "properly" P.S. I sent you an engine overhaul this A.M. He is in NJ so I thought he could save some shipping. I hope it works out for you.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I appreciate for the referral. I will keep you posted if it works out.
Author of "101 Projects"
Just a note - Engine Shops don't compete with Pelican (well, not directly),
My point - I have stricter standards for this Engine Rebuild Forum than the others - I really want to keep it clean, nice -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
-Wayne
Sometimes in life you just put out a fair product, for fair people
Bird. It's the word...
Christian
Thanks for being here.
John Forcier Current: 68L 2.0 Hotrod - build underway |
Thank You for the kind words
Thank you fishcop.
BY THE WAY, WE SHIP ANYWHERE IN THE WORLD Fishcop are you a park ranger?
When I first signed up I was a Fisheries Inspector (ergo Fishcop)
I now work as a plain clothes investigator for the Department of Natural Resources doing much more than just fish. The handle has stuck though.... ![]() PS Will definitely be interested in your headstuds next rebuild!
Hilbilly Deluxe
Hijack
--Hijack
Christian, is the flat black Turbo you have listed for sale in Pano the one that was in the"Excellence" article? For $20K it seems like someone will be getting a good deal. Tom |
Closing note:
The engine was reassembled with: - original 4x50 mm o-ring - a very thin layer of Curil Dirko around the o-ring area, keeping well clear of the oil pressure hole - case halves with Loctite 574 everything is fine now, after running the engine for more than 2 hours Thank you for all the info on this forum Andreas |
Irrationally exuberant
Congrats Andreas! I'm sorry for your suffering but it was a great education for the rest of us.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Good thread Andreas, thanks!
Closing note 2:
In March 2006, after at least 10000km on the engine, sealing is still bone dry! No problems any more. Andreas |
resident samsquamch
This is great info. I'm planning to follow Henry's case sealing methods to the "T". However in regards to number 8 nose bearing
A: Is it applied to the bearing itself...just the area that the o-ring is in? B: Is the entire bearing surface (well the part of the bearing that rests on the case) covered? C: Is the entire number 8 case surface covered (the number 8 bearing saddle)? Please advise experts!!! I'm so afraid that I'll do more harm than good if I screw this part up! Thanks, Jeff
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
abit off center
This is what Henry told me, I had the same question:
On #8 do you add 1211 around the oring area or the whole bearing surface? ""Very thin coat around entire bearing surface"".
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
resident samsquamch
Great! Then what I'll do is apply a thin coat to actual bearing saddle on the case...both case halves.
What a great thread!
Fishcop, don't feel too bad, or alone. I'm in Hawaii,
Jon |
Just my 2 cents. Why would anyone put any sealant inward of the o-ring? Let the oil flow that way naturally if it gets there. Any misplaced sealant will get pushed into the oil return channel
steve old rocket inguneer |
I hate freight charges
If I need to get my cases done Henry will get my business.
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
