Hi to all,
recently I got my freshly redone 2.4S ( is 2.7RS now) engine back. Unfortunately there is now a new oil leak coming from where the case halfes meet the o-ring for the nose 8 bearing. It is quite clear that the oil drips from there Now, before I would like to ask some questions, here some considerations beforehand. 1. The engine (4R mag case) was not leaking before. It was a much used engine though as P+C, valves + guides were complete out of spec. Oil pressure was always good though. 2. During the rebiuild the engine case was updated with time-serts, oil bypass modifcation 3. The workshop is a reputable workshop here in Italy 4. The newly rebuild engine has no other leak 5. The workshop explained me that he had recently problems with oil leaks in the nose 8 o-ring area as the last 3 rebuilds of 2.2 6. Of these rebuilds the second last rebuild was done with the original 4 mm o-ring without silicon masic. It leaked. The last rebuild (on my engine) was done with the 4.5mm o-ring with silicon mastic also. It leaks also , but less according to the workshop. 7. The workshop is using a reddish Curil sealant for the case (not the T offcourse) . He claims that Loctite 574 is best on alumium cases, but prefers the curil sealant on mag cases. Thank you for reading so far, hopefully someone of you can answer my questions. My goal is to resolve the problem of leaking , It looks to me like the workshop is doing something systematically wrong as the latest engines all leak. So 1 QUESTION: Is it true that on older mag cases the depicted area around the nose 8 o-ring is a weak point 2 QUESTION: Has someone ever fixed such a leak for definetely by using epoxy glue? 3 QUESTION: Has out of roundness been an issue on nose 8 bearing? Do you suggest buying a new nose 8 bearing block? 4 QUESTION: Do you all agree that the mounting method described by Wayne is reliable? If I remember well he suggests 4.5mm o-ring, with some curil T sealant. Case with thin layer of Loctite 574. 5 QUESTIONS: Before the workshop started the rebuild, I let him B. Andersons Thank you for your time Andreas , Cremona, Italy http://www.daedalussoft.com/classiccars/porsche2.4S_Targa.jpg |
Here the image Thank you for your time Andreas |
Try not, Do or Do not
# 8 main bearing bit your ass !
As an engine builder with many years experience we have seen this problem over
PS; judging by your picture, more prep work may have been indicated.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-04-2004 at 04:39 PM.. |
Bird. It's the word...
This thread is giving be a bad feeling... I recently closed my case up with a new #8 bearing
Should I start pulling it back down now?
John Forcier Current: 68L 2.0 Hotrod - build underway |
do it now, or do it later ?
How far along are you? One thing to remember, during the early 90s Porsche was having a 4% leak rate ( I'll guarantee you won't read that anywhere) on their band new 911 engines. They were leaking right on the dyno
Good luck
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Timing cams
Author of "101 Projects"
Yes, the early 3.6 engines were famous for their leaks. I have heard similar stories about oil leaks occurring under the 2.7 cars at the dealerships.
Anyways, there's not much good that I can say here. As Henry intimated, it sounds like the case was not properly prepared. You really need to align bore, or resize the case in order to get a good, leak-proof rebuild. A lot of people don't want to spend the money, or don't really believe that the cases warp I hate to say it, but the only way to really fix this leak is to tear down the engine -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thank you very much for the quick reply. Thank you very much Wayne for setting up this execellent forum,
I talked to the rebuilder, To Henry: The picture is not my engine, it is a picture I found on the web , its purpose was only to detail the leaking point!! I translated all your answers to the italian rebuilder, He did not do an out of round measurement; first because it is out of his workshop scope to rebore a case, Once the case is open again I will try to detail any problem encountered in that area, hopefully others will be able to learn from our mistake here! Probably I will go for the Loctite 574 sealant as it is Porsche Original. Have a nice day Andreas |
Irrationally exuberant
Wonderful info Henry!
thanks, Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The # 8 main bearing having too much clearance will not effect the way the crank turns. Because the bearing is loose in the case, it will align with the crank
574 is fine to seal metal to metal. Perhaps the best at that job, but is was not design to be flexible Good luck.
Michael
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
No, I didn't say that "the factory doesn't glue the case halves". Of coarse they glue the case halves. I don't build late model engines ( no water for us) but it's my understanding the Porsche uses 574 Loctite on there case halves. What I said was that " Porsche does not glue the # 8 main bearing into the case." The factory relies on the oil control channel
I hope this clears up that misunderstanding.
Senior Member
John Walker uses a sealant that does not harden. I used it,
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Henry,
OK. I wasn't trying to "bust your chops". I truly misunderstood what you said. Thanks for enlightening me.
Hello again,
please, could you enlight me some details that I couldn'grasp properly: 1. Do you put the Threebond 1204 in the o-ring groove? 2. Do you also apply Threebond 1204 to the case halfes sealing surfaces? My idea was to use Loctite 574 only for the case halfe surfaces Now I have the understanding that you put some soft sealer in the groove also. What type of sealant is Threebond? Is it as soft as Hylomar blue or is it black silicon stuff? Engine is out already Thanks to your info I will probably be able to reassemble over the weekend. Please confirm if you have time. (In the meantime I am busy answering MFI questions in another thread) |
Slumlord
Re: # 8 main bearing bit your ass !
Read pages 48 thru 53 again. This details all of the things that need to be done to the case in order to achieve a leak-free engine. If you don't follow these guidelines, the cases have a high probability of leaking. Back to the crankshaft again. Spinning it in its bore is a horrible I'm not sure what to tell you, but it doesn't sound like they have a whole lot of experience. At least they are standing behind their work, which is sometimes rare, here in the states... -Wayne
I agree with Henry on the sealant - 574 is a poor choice. Its designed as a gasket sealer. I would go with Curil-T, as I have had good luck with that. -Wayne
Re: Re: # 8 main bearing bit your ass !
Simply put, if the case is within spec There's no such thing as a free lunch with these engines - as many will confirm, they are very unforgiving when it comes to leaks. You've got to follow along carefully -Wayne
Loctite 574 is a Form-in-Place Anaerobic » Flange Sealant . Fast curing, medium strength compound specially formulated to cure through large gaps. It is not a gasket sealant.
Curil T on the other hand is a non drying, non hardening, non curing, sealant. It has limited use in large gap, high pressure applications. We only use it where smooth surfaces meet or on assemblies with gaskets that come apart often ( race gear boxes, etc.) For this unusual application ( high gap, high pressure) we use Threebond 1211 Silicone based anaerobic sealant that is both heat __________________
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-04-2004 at 04:44 PM.. |
