Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
magic930's Avatar
Firing Order for 87
A little confused by the description in Waynes book so I just want to confirm the firing order
1-6-2-4-3-5 on an 87 3.3 turbo,
(note the book says its different for various years)
and the distributer therefore moves counter clockwise?
thanks in advance
Old 06-07-2004, 08:22 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
ChrisBennet's Avatar
I thought the firing order was the same for all years?
The distributor turns "backwards" (CCW) on an SC compared to all the other motors.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 06-07-2004, 08:51 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
The distributors turn Counter Clock Wise for 911SCs 78 to 83 and 930 3.3 turbo from 78 to 89.
The firing order is the same for all 911 based engines.
1-6-2-4-3-5
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-07-2004, 11:47 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
magic930's Avatar
Thanks for the clarification Henry.
Old 06-07-2004, 12:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
Right - firing order is the same, distributor turns, and is wired, backwards...
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines101 Projects for Your Porsche Boxster & Cayman
Coming in 2012:
• 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997
Old 06-07-2004, 05:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
-Wayne
What does Wayne mean by 'wired backwards?'
Old 06-11-2004, 04:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Well, the firing order is 1-6-2-4-3-5. Cylinder number one will always be the one nearest the notch, and cylinder number 4 will always be 180 degrees oposite from it.
However, one will go 1-6-2-4-3-5 and other will go 1-5-3-4-2-6. Clockwise vs. counter-clockwise, or backwards.
I explain this on page 190.
-Wayne
Coming in 2012:
Old 06-11-2004, 04:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Thanks Wayne. I'll check my book.
Old 06-11-2004, 04:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
NO, it will stil go 1-6-2-4-3-5 as the spark plug wires are installed in that position, any other firing order would require new cams.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-11-2004, 05:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
You guys are both right, just not very clear. I'll give it a try.
On 78-83 911 SCs & 78-89 930 the ditr. turns counter clock wise (ccw). This means you start at the number one plug wire, generally marked on the dist. with a small line and go ccw 1-6-2-4-3-5.
On all other Porsche 911 dist. you start at the number one plug and go clock wise 1-6-2-4-3-5.
I hope this clears things up.
Henry Schmidt
Ph: 760-728-3062
Old 06-11-2004, 08:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
See the book - a picture is worth a thousand words...
-Wayne
Coming in 2012:
Old 06-11-2004, 09:32 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
-Wayne
Sorry Wayne I don't have THE book.
I guess I'll have to use my experience and hope for the best.
Henry Schmidt
Ph: 760-728-3062
Old 06-12-2004, 03:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Brorag
Brorag's Avatar
ouch!
Old 07-01-2012, 11:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Robbbyg's Avatar
Counter clockwise, clockwise,,
im working out firing on a 1977 930, with the above info does this mean that a 77 is clockwise from number one??
can of worms here
I used to have a Budgie
Old 05-07-2013, 04:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
proffighter's Avatar
1-6-2-4-3-5
100% correct!
BTW for this reason all camshafts can be used in principle for each engine...
Roland
930 Turbo '81 Too many modifications to list
Old 05-07-2013, 01:54 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Robbbyg,
Just turn the engine over by hand and see which way the rotor turns.
-Andy
Old 05-07-2013, 02:14 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
Schleprock
fastfredracing's Avatar
A 77 930 turns clockwise
1976 930( peru red usa) ,1976 930 (black euro), 1980 euro SC, (guards), 2004 BMW 325 IX sportwagen,1997 BMW M3, 2004 Silverado Duramax quad cab dually, 1997 Jeep , 1985 f 350 dump truck, 1987 ramcharger plow truck.
2008 Subaru wrx.
Old 05-07-2013, 02:51 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
PrimeMvr's Avatar
Anyone know why they did this? CW for some CCW for others? I only ask because I'm a collector of random facts
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Pilot Sport/18" Kinesis wheels/Big Red brakes/LSD
83 SC Cab - Guards Red - BBS wheels, otherwise stock; currently under the knife
Old 05-08-2013, 07:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
