magic930's Avatar
Firing Order for 87
A little confused by the description in Waynes book so I just want to confirm the firing order
1-6-2-4-3-5 on an 87 3.3 turbo,
(note the book says its different for various years)
and the distributer therefore moves counter clockwise?
thanks in advance
Old 06-07-2004, 08:22 AM
Irrationally exuberant
ChrisBennet's Avatar
I thought the firing order was the same for all years?
The distributor turns "backwards" (CCW) on an SC compared to all the other motors.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-07-2004, 08:51 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The distributors turn Counter Clock Wise for 911SCs 78 to 83 and 930 3.3 turbo from 78 to 89.
The firing order is the same for all 911 based engines.
1-6-2-4-3-5
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-07-2004, 11:47 AM
magic930's Avatar
Thanks for the clarification Henry.
Old 06-07-2004, 12:21 PM
Originally posted by Wayne at Pelican Parts
Right - firing order is the same, distributor turns, and is wired, backwards...
-Wayne
What does Wayne mean by 'wired backwards?'
Old 06-11-2004, 04:29 PM
Author of "101 Projects"
Wayne 962's Avatar
Well, the firing order is 1-6-2-4-3-5. Cylinder number one will always be the one nearest the notch, and cylinder number 4 will always be 180 degrees oposite from it.
However, one will go 1-6-2-4-3-5 and other will go 1-5-3-4-2-6. Clockwise vs. counter-clockwise, or backwards.
I explain this on page 190.
-Wayne
Old 06-11-2004, 04:34 PM
Thanks Wayne. I'll check my book.
Old 06-11-2004, 04:43 PM
NO, it will stil go 1-6-2-4-3-5 as the spark plug wires are installed in that position, any other firing order would require new cams.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-11-2004, 05:52 PM
You guys are both right, just not very clear. I'll give it a try.
On 78-83 911 SCs & 78-89 930 the ditr. turns counter clock wise (ccw). This means you start at the number one plug wire, generally marked on the dist. with a small line and go ccw 1-6-2-4-3-5.
On all other Porsche 911 dist. you start at the number one plug and go clock wise 1-6-2-4-3-5.
I hope this clears things up.
Henry Schmidt
Ph: 760-728-3062
Old 06-11-2004, 08:21 PM
See the book - a picture is worth a thousand words...
-Wayne
Sorry Wayne I don't have THE book.
I guess I'll have to use my experience and hope for the best.
Henry Schmidt
Ph: 760-728-3062
Old 06-12-2004, 03:50 AM
Brorag
Brorag's Avatar
ouch!
Old 07-01-2012, 11:31 AM
Robbbyg's Avatar
Counter clockwise, clockwise,,
im working out firing on a 1977 930, with the above info does this mean that a 77 is clockwise from number one??
can of worms here
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 05-07-2013, 04:38 AM
proffighter's Avatar
1-6-2-4-3-5
100% correct!
BTW for this reason all camshafts can be used in principle for each engine...
Roland
930 Turbo '81 Too many modifications to list
Old 05-07-2013, 01:54 PM
Robbbyg,
Just turn the engine over by hand and see which way the rotor turns.
-Andy
Old 05-07-2013, 02:14 PM
fastfredracing's Avatar
A 77 930 turns clockwise
No left turn un stoned
Old 05-07-2013, 02:51 PM
PrimeMvr's Avatar
Anyone know why they did this? CW for some CCW for others? I only ask because I'm a collector of random facts
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 05-08-2013, 07:27 PM
