Wo ist die Rennstrecke?
DonE's Avatar
Piston Squirters
I am cleaning my case one last time before putting it all together and find that I can not blow air through half of them (they seem plugged). Even when I try to run some carb cleaner through the holes, I either get a drip or nothing at all. The others seem fine. I also noticed the small ports seem to be spring loaded??...
3.3L 930 case
Suggestions?
Thx
Old 11-03-2004, 08:18 PM
Irrationally exuberant
ChrisBennet's Avatar
Try using a rubber tipped air nozzle if you aren't already. I posted some pictures in this thread: Piston Squirters!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-04-2004, 05:05 AM
Jubbie's Avatar
From the "don't ask me how I know this" files...
You are blowing from the bearing side right?
There is a check valve in there that keeps flow from going from the squirter to the bearing.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 11-04-2004, 06:18 AM
DonE's Avatar
Thanks Chris - problem solved.
Old 11-04-2004, 06:22 AM
DonE's Avatar
Thanks John
Old 11-04-2004, 06:29 AM
