Wo ist die Rennstrecke?
Piston Squirters
I am cleaning my case one last time before putting it all together and find that I can not blow air through half of them (they seem plugged). Even when I try to run some carb cleaner through the holes, I either get a drip or nothing at all. The others seem fine. I also noticed the small ports seem to be spring loaded??...
3.3L 930 case Suggestions? Thx |
Irrationally exuberant
Try using a rubber tipped air nozzle if you aren't already. I posted some pictures in this thread: Piston Squirters!
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
From the "don't ask me how I know this" files...
You are blowing from the bearing side right? There is a check valve in there that keeps flow from going from the squirter to the bearing.
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Thanks Chris - problem solved.
Thanks John
