F1BADUDE's Avatar
Twin Plug
I am rebuilding a 69 2.0L for club race project and want to go twin plug. I have heard mixed things about crank fire and am looking for 12 plug distributor. Can anyone tell me where I could find one or someone who can make one for me?
Thanks,
BA
Old 06-12-2004, 06:37 PM
beepbeep's Avatar
In case rules aren't hampering you, it's much easier and more reliable to go for direct-fire standalone ignition. Dual-plug distributors are very pricey items and cost as much as complete aftermarket ignition kits despite being less reliable and untunable.
Thank you for your time,
Old 06-12-2004, 07:31 PM
Porschephd's Avatar
I use crankfire on all the TP motors I build. Never an issue. We set the plugs at 40 thou and all is good. Direct fire is cheaper and more adjustable.
Stephen
94 3.6Turbo 6-speed AWD
Old 06-12-2004, 09:16 PM
No Expert
jgparker's Avatar
To answer your question, I think Andial does this conversion. I hear the cap alone is close to 1K. I'm not sure if it can be done on a 2.0 distributor.
http://andial.com/content/911/twinplugdist.htm
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 06-13-2004, 07:02 AM
sayah's Avatar
Has anyone tried to adapt a used Bosch DME from a BMW, lets say, to a 2.0 engine? You could modify an old flywheel, get some sensors and a DME, put 6 coil packs on the spark plusgs, a new chip, etc, etc.
Should work, no?
Thinking outside the box.
sayah
Old 06-13-2004, 08:48 AM
F1BADUDE's Avatar
any recomendations on a good crankfire system?
Old 06-13-2004, 11:32 AM
Author of "101 Projects"
Wayne 962's Avatar
Lots of good questions here. First off, the BMW DME thing has been done, do a search on "BMW DME" and you will find a bunch of answers.
Secondly, I can't think of anything wrong with crankfire, except for the cost, and the fact that it looks "non-stock." Other than that, hands down, it is the way to go. The twin-distributors have lots of problems (no advance in some, expensive, non-available caps, etc.) They do look soooooo coooool though in your car. That would be the only reason for installing one in my opinion.
-Wayne
Old 06-13-2004, 12:36 PM
Porschephd's Avatar
Dollar per dollar there isn't any comparison. Dual HPXs, wires and even a map sensor is still cheaper in the long run over the dated RSR stuff. Don't forget you have to have dual CDIs, dual coils etc. At the end of the day the other route is cheaper. Also don't forget that a standard dist can move 10 degrees with a worn dist gear on the crank. A direct fire is accurate within 1/4 degree at all times. We typically sell these systems at around 1550.00 to give a comparison on cost of the traditional way.
Stephen
Old 06-13-2004, 01:51 PM
Send a message via AIM to Oldporsche
Cool
Stephen Kasper (Porschephd) has the answer down.
I have investigated many methods but direct fire makes the most sense, if you don't have to look stock.
You might investigate megajolt-lite for another look at a direct fire or the Ford EDIS ignition.
Good luck,
David Duffield
Old 06-13-2004, 02:25 PM
Grady Clay's Avatar
Remember you can still have a gutted twin plug distributor in place for show (with a bad cap) and a crank fired system hiding behind the engine.
You can even disguise the fact it is twin plug by keeping the exhaust plug connectors and wires inside the lower valve covers. Use a gutted single plug distributor and OE wires.
A little subterfuge goes a long way so long as you don’t evade the rules.
BA, Give us a rundown on the retail cost of the system you installed.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 06-13-2004, 03:16 PM
Air Medal or two
afterburn 549's Avatar
also a twin plug cap is 600.00 dollars!! thats enough to do somthing else......think sds.com
imo
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-13-2004, 03:20 PM
Porschephd's Avatar
Hey David!! Long time no talk! Next time you are in KC look us up again. Things have changed a wee bit
Stephen
Old 06-13-2004, 03:32 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
are you using some high dome pistons in this engine or running a really high CR??? if you arent you dont need to twin plug it and can save some money.
74 911s neverending story. two feet and a jetta for now.
Old 06-13-2004, 09:19 PM
Hilbilly Deluxe
emcon5's Avatar
I am partial to Rennsport's 964 conversion.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-14-2004, 11:28 AM
