Twin Plug
I am rebuilding a 69 2.0L for club race project and want to go twin plug. I have heard mixed things about crank fire and am looking for 12 plug distributor. Can anyone tell me where I could find one or someone who can make one for me?
Thanks, BA |
In case rules aren't hampering you, it's much easier and more reliable to go for direct-fire standalone ignition. Dual-plug distributors are very pricey items and cost as much as complete aftermarket ignition kits despite being less reliable and untunable.
Thank you for your time, |
I use crankfire on all the TP motors I build. Never an issue. We set the plugs at 40 thou and all is good. Direct fire is cheaper and more adjustable.
Stephen 94 3.6Turbo 6-speed AWD |
No Expert
To answer your question, I think Andial does this conversion. I hear the cap alone is close to 1K. I'm not sure if it can be done on a 2.0 distributor.
http://andial.com/content/911/twinplugdist.htm Good luck, JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
Has anyone tried to adapt a used Bosch DME from a BMW, lets say, to a 2.0 engine? You could modify an old flywheel, get some sensors and a DME, put 6 coil packs on the spark plusgs, a new chip, etc, etc.
Should work, no? Thinking outside the box.
sayah |
any recomendations on a good crankfire system?
Author of "101 Projects"
Lots of good questions here. First off, the BMW DME thing has been done, do a search on "BMW DME" and you will find a bunch of answers.
Secondly, I can't think of anything wrong with crankfire, except for the cost, and the fact that it looks "non-stock." Other than that, hands down, it is the way to go. The twin-distributors have lots of problems (no advance in some, expensive, non-available caps, etc.) They do look soooooo coooool though in your car. That would be the only reason for installing one in my opinion. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Dollar per dollar there isn't any comparison. Dual HPXs, wires and even a map sensor is still cheaper in the long run over the dated RSR stuff. Don't forget you have to have dual CDIs, dual coils etc. At the end of the day the other route is cheaper. Also don't forget that a standard dist can move 10 degrees with a worn dist gear on the crank. A direct fire is accurate within 1/4 degree at all times. We typically sell these systems at around 1550.00 to give a comparison on cost of the traditional way.
Stephen Kasper (Porschephd) has the answer down.
I have investigated many methods but direct fire makes the most sense, if you don't have to look stock. You might investigate megajolt-lite for another look at a direct fire or the Ford EDIS ignition. Good luck, David Duffield |
Remember you can still have a gutted twin plug distributor in place for show (with a bad cap) and a crank fired system hiding behind the engine.
You can even disguise the fact it is twin plug by keeping the exhaust plug connectors and wires inside the lower valve covers. Use a gutted single plug distributor and OE wires. A little subterfuge goes a long way so long as you dont evade the rules. BA, Give us a rundown on the retail cost of the system you installed. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Air Medal or two
also a twin plug cap is 600.00 dollars!! thats enough to do somthing else......think sds.com
imo
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Hey David!! Long time no talk! Next time you are in KC look us up again. Things have changed a wee bit
are you using some high dome pistons in this engine or running a really high CR??? if you arent you dont need to twin plug it and can save some money.
74 911s neverending story. two feet and a jetta for now. |
Hilbilly Deluxe
