126coupe's Avatar
2.0L Head Gasket Dumb Question
My first 2.0L engine! Which way??
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 06-17-2004, 08:04 AM
The perforated side goes toward the head. Have fun,Karl
Old 06-17-2004, 03:38 PM
126coupe's Avatar
Thanks now I dont have to dig out the factory manual
28' Pace Trailer
Old 06-18-2004, 07:57 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Sorry guys. No one wants to be a "KNOW IT ALL". The information provided by Karl is incorrect. Although it is really no big deal, if memory serves me properly, Porsche recommends that the perforation goes towards the cylinder.
On a race engine there is really no need for the head gasket. It does not seal the head. The combustion sealing is performed by the cylinder top. I believe the gasket was designed to prevent oil leaks during cool down. Either way the perforation goes towards the cylinder.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-18-2004, 08:09 AM
126coupe's Avatar
Thanks Henry! Perfect example of why everthing on this
board is not fact!
28' Pace Trailer
Old 06-18-2004, 08:12 AM
126coupe's Avatar
OK I dug out the Porsche Factory Manual, Henry good memory
28' Pace Trailer
Old 06-18-2004, 08:25 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Henry, do you use Head gaskets on the motors you build for Terry???
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 06-18-2004, 08:28 AM
Why would'nt you use them if you had the option??
Mark Scott
Vintage 911 Racer
Old 06-18-2004, 08:31 AM
126coupe's Avatar
Henry might answer this better but I would think removing
it would raise the Compression ratio, and since I did my Compression ratio measurements already I opt to use the head gaskets.
28' Pace Trailer
Old 06-18-2004, 08:39 AM
Hi Mark
On two liter engines that I build I use the head gasket. What I was saying is that it's not really necessary. They don't hurt, so I use them. If I was trying to make it to a race and didn't have them, I would go without.
I make a spacer kit that allows you to use 2.2 heads on a 2.0 cylinder ( bigger valves, better combustion camber) and it does not use a gasket or CE ring and there have been no sealing issues.
Henry Schmidt
Ph: 760-728-3062
Old 06-18-2004, 08:42 AM
Mark wrote
"Henry might answer this better but I would think removing
it would raise the Compression ratio, and since I did my Compression ratio measurements already I opt to use the head gaskets".
If the cylinder does not fit flush against the head then the engine will not seal. The head gasket crushes to a point where it does not effect the gap between the head and cylinder, hence no effect on the compression ratio.
Henry Schmidt
Ph: 760-728-3062
Old 06-18-2004, 08:47 AM
Thanks Guys......
Nothing like a little schooling on a Friday Morning.
Mark Scott
Vintage 911 Racer
Old 06-18-2004, 08:53 AM
Im sorry I was thinking cylinder and typed head sorry again I feel like a dumbass. Karl
Old 06-18-2004, 03:28 PM
