Senior Member
john_colasante's Avatar
3.6 cylinder leakage fix and case mods
What are the modifications necessary to build a leak free 3.6 liter engine, and what are the costs?
What methods can be used to seal both the cylinder/case union and the cylinder/head union?
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 06-21-2004, 11:05 PM
304065's Avatar
HI JC
Some good info here?
964 O-ring fix/update
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-22-2004, 11:56 AM
Senior Member
It's all there, thanks JC!
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 06-22-2004, 04:02 PM
Bill Verburg's Avatar
JC, is this for your Cup car? Ingo had his stock cylinders machined by Walt at CE. The cylinder base gaskets were updated for the 109mm 993RS spiggots, as far as I know the stock 964 o-rings are adequate most of the time. Some builders put a dollop of something like Dow Corning 730 anaerobic sealant for extra insurance.
I see that you are in the market for a replacement aluminum hood as well?
Bill Verburg
Old 06-22-2004, 04:04 PM
Senior Member
Yes Bill, I need to start planning for a rebuild. My cylinders are leaking more and more lately.
Also, take a look at this thread. Can you lend some insight there?
964 engine rebuild 11.3:1 compression
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 06-22-2004, 04:12 PM
I'll bet OZ knows
and I'll bet Bob will find out.
I don't really know as I only ran into the base issue and wasn't as concerned w/ taking the rest of the specs to the limit.
PCA wouldn't allow JEs made to the 964 11.3 spec and dome shape?
Here's a pic of the bottom of your engine that I took at the Glen
Doesn't look that bad
Bill Verburg
Old 06-22-2004, 07:17 PM
