Removing sealant between the case halves
I am rebuilding my 3,2 engine. I have dismantled the whole engine and cleaned all part except the mathing faces between the case halves. Does anyone have a tip how to removed the old sealant without damaging the mathingfaces?
Tor Erik Schjølberg
85 911 Carerra
83 Ford Capri 2,8I
Old 07-20-2004, 07:26 AM
Irrationally exuberant
ChrisBennet's Avatar
Permatex Gasket Remover works great. Be careful not to get any on your engine stand of it will take off the paint. I use a one sided razor blade after that and scrape in the direction of the seam so if I make a nick it won't make a groove leading from in to outside the case. I pre bend the razor blade slightly so when I press down it flattens out - it doesn't tend to catch the edges that way.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-20-2004, 03:44 PM
Who is John Galt?
Rondinone's Avatar
I used 100% acetone and scotch brite pads.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 07-20-2004, 04:49 PM
Thanks for you advices. I bought CRC gasket remover today. Will try it later today.
Tor Erik Schjølberg
85 911 Carerra
83 Ford Capri 2,8I
Old 07-21-2004, 07:34 AM
