993 block w/964 heads and valve train
I'm looking at an engine with this combination.
I rebuilt my 3.0, but my education doesn't go much beyond that.
Am I right that the 993 cylinder tops have the grove and sealing ring?
What else is good/bad/interesting with this combination?
Thanks!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 12-16-2005, 09:21 PM
Bill Verburg's Avatar
from ~'92 up they used the new style head gaskets
generally the 993 heads are considered to be more desireable because of larger ports, lighter valves and valve train, etc. vram heads also have larger valves
the 993 crank is heavier and stronger but the whole rotating recipricating assembly is lighter.
all in all I would rather have a full on 993 than a 964 or 964/993 combo
Bill Verburg
Old 12-17-2005, 06:07 AM
DW SD's Avatar
Are the combustion chamber volumes equal on 964 and 993 heads? IE compression ratios equivalent?
1971 RSR - interpretation
Old 12-20-2005, 09:14 AM
Nominal cr is the same
the 993 heads were a big redesign from 964, among the differences are alloy composition and rocker reconfiguration.
Bill Verburg
Old 12-20-2005, 03:05 PM
