Alternative N.A. Motor For Carrera?
Somes friends were discussing, over a Friday beer, what you would do with the following requirements:
- A normally aspirated 911 motor to use in a Carrera - Mostly street use, and occasional AX/DE - Keeps heating and A/C, although components can be moved/changed - Runs on pump premium and doesn't attract noise tickets - Can be swapped with the stock 3.2L for smog tests One proposal was a stock 3.6L from a 964/993. At the other extreme, a 3.8L on a 3.6L case with individual throttle bodies, F.I., and Motec, sort of a detuned racer. What would you suggest?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
I've had a stock 3.6 liter 964 and a modified 3.8 liter 993RS in mine. Both are umm... adequate
![]() Heat isn't a big issue, finding a class to race in is Motec/TWM etc. are also very nice but also very expensive. How nice can you afford?
get another 3.2, build it to a 3.4 keep the stock induction but use the plastic manifold, lighter and smoother. throw some wilder cams on it and raise the CR a bit and get a custom chip from Steve Wong. Or just try to push it to the limits with the stock engine.
74 911s neverending story. two feet and a jetta for now. |
On the same page as the 3.2 to 3.4, you could do a 3.5 conversion, just requiring some machining to the case to allow for the oversized skirts. Just an idea :-)
Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
if you wanna spend 10k i say keep the car, throw some money towards suspension, get 3.4 p&c's, plastic 3.2 intake, steve wong chip, wilder cams and drive the crap out of it. oh and bore out the throttle body
I would rather be driving
Keep it stock and buy some seat time. Then upgrade the suspension and buy more seat time. Add some safety stuff and still more seat time. YMMV
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thread Tools | |
Rate This Thread | |
