Irrationally exuberant
ChrisBennet's Avatar
Bad batch of rocker shaft seals?
The latest rocker shaft seals I got had some defective ones. Of the 10 ones I used, 4 had tears in them. None of the other 12 from my old stock had any defects. Has anyone else experienced this?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-09-2004, 12:59 PM
Unregistered
sammyg2's Avatar
I just installed a set last month and had no problems with them, must be a different batch
Old 11-09-2004, 03:21 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Properly installed rocker shafts in undamaged cam tower don't need seals.
I've seen them, we stock them and never seen a need to install them.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-09-2004, 03:55 PM
Next you'll be telling me I don't need to wear that garlic around my neck while torquing rod bolts.
The seals are a belts and suspenders thing for me...
-Chris
Old 11-09-2004, 04:44 PM
vichang4's Avatar
I used the seals also. It just seemed like easy insurance.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 11-09-2004, 05:14 PM
Jubbie's Avatar
Just put four of 24 in (only got to the cam adjustment) and they were fine. Let you know Thanksgiving if the rest ended up fine.
When it comes to keeping oil in an aircooled engine, I'll use belts, suspenders, bailing wire, and duct tape to keep the slick stuff inside!
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 11-14-2004, 06:35 PM
