Air Medal or two
How to C/R ratio??
Will this work...put a "o" ring on the fire ring groove -T.D.C. it. Put plug hole up and fi it (cout the cc) Put the piston at B.D.C. fill it the rest of the way up.....will this work??
thanx...........I am just looking for a simpler way to do c/rs
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Doesn't get much simplier than the procedure illustrated here
ATF also works.
Sherwood |
Air Medal or two
Thats the pt..would ths be more simpler??.......One less thing to do....less room for error???...
Irrationally exuberant
It looks a lot easier than it is IMO. I must admit, I have a difficult time getting consistant results. It takes very little CC error to make a large change in compressio ratio.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Air Medal or two
Yea I know Criss....Just lookin for a simpletons way...there has to be a simpler way.......It would seem if all the heads were cc out to the exact then the rest would be more ezer.........
Thread Tools | |
Rate This Thread | |
