adomakin's Avatar
can i re-use my case through bolts?
Ive got the washers and nuts on order but are the bolts ok to re-use? the engine is a 78 3.3 turbo
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-22-2004, 02:26 PM
Unregistered
sammyg2's Avatar
Yes, as long and they don't show any signs of damage you can re-use them.
Old 11-22-2004, 02:33 PM
Irrationally exuberant
ChrisBennet's Avatar
The through bolts, nuts and washers are reused. I've never heard of using new ones.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-22-2004, 03:31 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Yeah, what they said. ARP supposedly either has or is developing a case-thru bolt kit as an option (and probably an expensive one at that).
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-22-2004, 06:33 PM
adomakin's Avatar
thanks blokes
Andy
Andy
Old 11-22-2004, 11:00 PM
Try not, Do or Do not
Henry Schmidt's Avatar
TORQUING A COURSE THREAD BOLT ???
We typically reuse case through bolts. That said, we feel that the up-dated fine thread bolts are preferable to the early course thread bolts. We up-grade all performance engines to these bolts. They are found on engines from 78 and later 3.0, 3.2 and 3.3 turbos. Torquing a fine tread nut is always preferable to torquing a course thread. Porsche must agree or they would not have changed them. Will it make a difference you can see. I think not, but we've got them so we use them.
BTW: Porsche race engines have a special case through bolt. They are slightly larger and have a wide section where the case halves meet that work like shuffle pins to help the case stay aligned. The wide section has a slot cut in it to allow for oil to flow past it. If ARP is making case bolts let's hope they follow Porsche's lead. If not perhaps Supertec should make some. Who knows?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-23-2004, 07:57 AM
adomakin's Avatar
thanks Henry.
Andy.
P.S. got some of your head studs the other day. very nice!
Andy
Old 11-23-2004, 10:51 AM
