Standard/Standard?
When someone is refering to a crank, why do they say STD/STD? Why not just standard?
Paul
My ignition is retarded. |
STD/STD means standard size on the rod journals and standard size on the main journals.
John Dougherty Dougherty Racing Cams |
I see. Thanks John.
Author of "101 Projects"
Bearings are the same way. You can have bearings that have a larger outer shell (oversized) to compensate for worn bearing surfaces in a case. Or, bearings that have a larger inner shell, to compensate for worn jounals on a crank.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
