Engine Finished, In car and runs!
This is a stock rebuild of a 2.4E MFI, Had 1 small problem getting it to run, CDI had issues and points (needed cleaning), Also I must have been asleep putting the left cam oil line on as it wasn't tightend but other than that went smoothly, Engine runs and idles and I have only set the timing
This is the Car after a 10+ year resto almost ready for the PCNZ concours on 5th December
Thanks to all that have contributed advice (and in some special cases parts)
Neven
Old 11-21-2004, 06:36 PM
Neven,
Magnificent job! I'm sure you'll get many years of enjoyment out of it.
-Andy
Old 11-21-2004, 07:10 PM
Bird. It's the word...
Fishcop's Avatar
Great work... is that Pastel Blue?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-21-2004, 07:13 PM
John
It looks a bit darker in real life the colour is 'Icing Blue'
Neven
Old 11-21-2004, 07:17 PM
magic930's Avatar
Engine looks great!... I see a hose connected to your exhaust. Did you run it on that stand?
Old 11-21-2004, 07:57 PM
I was wondering if someone would ask that, No it is a budget flow bench for setting up the throttle bodies (which I'd rebuilt), When you put a cylinder at TDC with valve overlap only that cylinder has a path from the exhaust thru to the intake (both valves open), The hose is connected to a vaccum cleaner, I then used a synchrometer to measure airflow for each cylinder at idle and part throttle settings, you can do it for more than a minute at a time for the vacuum cleaner overheats!
It worked well though when I first ran the engine I was only slighlt out between the left and right backs
Neven
Old 11-21-2004, 08:04 PM
Fishcop's Avatar
Clever...
John Forcier
Old 11-21-2004, 08:17 PM
Warren Hall Student
Bobboloo's Avatar
The car and the motor look fantastic.
Anything worth having never comes easy so I'd say your car is priceless!
Now about that ride height...
Paris Drakar?
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-22-2004, 02:38 AM
Bandwidth AbUser
Jim Richards's Avatar
Paris Drakar?
Neven, fantastic job on your engine and your E looks great!
Jim R.
Old 11-22-2004, 04:45 AM
I would rather be driving
jpnovak's Avatar
Another longhood set for many years of enjoyment. Glad to hear that its running smoothly. I like the thought on the flow test.
Old 11-22-2004, 07:31 AM
Bobby
Well spotted, The ride height is high at the back, needs to come down about 10mm, Its not Paris/Dakar settings! Maybe you guys with flares and lowered suspensions have forgotten what a std 911 looks like :-)
Neven
Old 11-22-2004, 10:23 AM
Party Member
viejopatron's Avatar
Neven,
That "budget flow bench" is very clever. As far as ride height, I hear that standard height is making a comeback, probably a result of all the SUVs on the roads here in the states.
Gary
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 11-22-2004, 11:51 AM
Warren Hall Student
Bobboloo's Avatar
Neven,
Actually I haven't forgotten, I just couldn't resist a chance to show what Porsche nerds Jim and I are.
P.S. The car really is inspirational.
Bobby
Old 11-25-2004, 01:47 AM
Bobby
The car is off to the suspension place today to be lowered, you didn't comment on the 1 degree +ve camber at the rear
(which we hope to get rid of by lowering), I know its offtopic but I thought you might appreciate this photo
Old 11-25-2004, 11:23 AM
adomakin's Avatar
oh my god. Neven you are one HARDCORE MUTHAHUBBARD! you have just invented a new form of restoration. its called EXTREME REBUILDING!
Andy.
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-25-2004, 01:48 PM
Andy
You'll appreciate that the car is ex UK (That darn salt gets everywhere), came to NZ about '85, I'll be putting up a website with more photos so stay tuned!
Old 11-25-2004, 01:54 PM
adomakin's Avatar
yeah, bloody england with its bloody rot. oh well.
Andy
Andy
Old 11-25-2004, 02:11 PM
Warren Hall Student
Bobboloo's Avatar
Wow that's insane.
How many times did you go to lift the pan off only to find yet another spot weld you missed?
I just wish I could retire so I could devote myself to a restoration of that degree. What fun.
Bobby
Old 11-25-2004, 08:55 PM
