what can be done w/ a 2.2?
I don't know whether it's a T, E, or S.... just stumbled upon it and the owner just took the carbs off of it for a different build. So there is a complete, apparently strong-running (man is legit, no reason for deception) 2.2 w/o any induction. What could this engine be built into? Is 2.7 the biggest it can get? Does it *have to* use carbs or can some form of CIS be utilized too?
No, I don't have a big budget so this would be something I'd be doing at my leisure, using whatever parts I can source... so if a 2.8 rsr is possible but the P/C's are in the unobtainium then I'm not really interested in that. I'm looking for some reliable power/torque that amounts to more than my stock 73.5 CIS T motor.
dave 1973,5 |
Bandwidth AbUser
Hahaha! Dave, are you getting into the NoVA arms race, too?
Jim R. |
Anything from mild to wild. Given your 2.4TK baseline and an eye on the budget, I'd suggest the following:
Using the existing case and heads: 2.2S JE pistons and E or Solex cams, throw on a pair of Zeniths. For some more money you can go up to 85mm pistons for a few more cc's. If you want to crack the case and replace the crank with a 2.4/2.7 crank, you can then easily build up something like a 2.4E with carbs. Since your on a budget -- Zeniths will still be fine. If you really want to go nuts, keep your eye on eBay for a used MFI system. But the $'s are going up. If you want to do more then that, you'll most likely just want to start with the 7R case from your 2.4TK and build up a 2.7RS style motor with either carbs or MFI.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Thanks John. Guess I'll still sit this out and wait for a nice 3.0 to yank my wallet.
) The Open Lift Day at RJ's heavenly garage didn't help things, especially when I saw a recently dropped, lonely and unwanted, 2.2 sitting on the floor. I mean really, how much could that thing be worth to him.....?
dave 1973,5 |
}{arlequin;
A carb'd high compression 2.2 with solex cams would be a pretty significant step up in power from what you've got now. The torque would be down a little bit because of the reduction in capacity, but most likely not by much given an increase in CR and the more aggressive cams. Besides the "kick" when the motor comes on-cam is worth the price of admission!
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 12-09-2004 at 01:41 PM.. |
Author of "101 Projects"
There are big differences between the 2.2T and 2.2E/S motors, with the T having these negative characteristics:
- Weaker mag case (not a 7R) - Zenith carbs - Non-counterweighted crank - Small port heads - T pistons - T cams So, if you want to build a good, powerful motor, you don't really want to start with a 2.2T. You'd have to toss out the case, crank, carbs, heads, and pistons. After that, there's not much left. 2.2T motors are best left as 2.2T motors... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne; did the 2.2E's and S's already have the 7R case? I thought the 7R case didn't appear on the scene until some time in '74.
Zenith carbs? I'm not aware of them being any better or worse then Weber 40's with the exception of there being fewer jetting options. But if you're clever and on a budget, I believe that the Zeniths will be as good as the Webers if you modify Weber venturis to fit the Zeniths. Given that Zeniths are available for a couple of hundred bucks and Webers seem to be starting above $500 + manifolds, it's certainly not a bad trade-off. Non-Counterweighted crank? Lots of guys race with them. For street use I'm not aware of any issues with them. Small ported heads? Are they 32 mm's or less? If their less it would most likely be best to open them up a bit. If their 32 mm's, they should be fine for the street use in the application that }{arlequin described. T Pistons: OK, a little low on CR. If anything I'd suggest getting a new set of pistons and cams and "let 'er rip!". (Disclaimer - of course the hidden costs still exist of having the cylinders freshened and doing all of the normal "top end" rebuild stuff. Keep in mind not all of us has the budget to replicate a factory RSR. Many of us have to be clever and keep an eye on a total budget that may be less then what some people on this BBS spend on tires! That's OK! All he wants is something that's more fun then a 2.4TK. That shouldn't be too difficult.
Buy Mega Squirt controller, six used fuel injectors (~250cc),used Garrett T3 turbo and some tubing.
Place turbocherger on the left/back side of engine, slightly raised, let oil drain from turbo go to lower part of chain cover. Cut & paste existing heat exchangers until they "blow" into turbo, take oil-line from turbo by slicing into pressure switch. Use sheet tubing (or maybe Carrera plenum, if you find one) to build intake, add and old intercooler if you have one (old SAAB 900 IC costs around 100$ and is physically small), set boost to ~0.6 bar, tune MS accordingly and you'll have a peppy little engine. It's originally low C/R would be just fine when turbocherged, just like it "small" ports (they are as big as ones on 930). Cams are allright as well. All this should cost around 1000$ in parts... plus some work (nothing too complicated). Even if everything blows up (it shouldn't) you haven't spent much and you would shurely learn a lot during process. You should have around 220hp w/o problems with this setup.
Thank you for your time, Last edited by beepbeep; 12-10-2004 at 06:20 AM.. |
LOL, beep.... that would be a fun ride!
Thanks for all the suggestions guys. It would seem like too big of an expense/effort to go through all that just to end up w/ *somewhat* more power (but no tq) over what I have now. It just looks like the overall cost in finding a 3.0 and spending some $ on freshening it would be lower that building a small displacement screamer from scratch. Looks like I also have some reading to do to catch up on what engine parts are the desirable ones... BTW, is there such a thing as a short stroke 3.0? Maybe turned into a 3.2? Can the 3.2 survive w/o twinplugging? Thanks for the responses.
dave 1973,5 |
Bob
923/912E (2.1l OEM EFI '99 F150 4x4 Chipped (who cares) LLVL in the LBC... "Long Hoods Rule" "RICE - The Breakfast of Champions" |
Bandwidth AbUser
John, everything I've heard echos what you've posted. A 2.2, even a 2.2T, can be made into a real fun engine!
Jim R. |
Home of the Whopper
If you stroke a 2.2T to a 2.4 you'll have a 2.4T with ~2.4S compression. Definitely an engine with an awesome torque curve for street driving. The early mag cases are fine for the ~135hp. The zeniths will work fine too. The only real problem with the 2.2T's was the dizzy.
7R cases were available in 73. As far as I know, all 73.5T's had them, and some later 73E and S's.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
2.2 E stroker HP output
really happy with this set up as a daily driver. pulls all the way from low rpms to 7K. dyno graphs are at the bottom of the post. matt
Matt 72 911T Targa - Sold Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat. Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!! Last edited by kucharskimb; 12-10-2004 at 12:32 PM.. |
that's a great link, thanks. Now it makes me wonder what type of 2.2 is lying around that guy's garage. Maybe it's an S?! Probably not but even if it's an E I'd have to seriously consider
dave 1973,5 |
-Wayne
It would be difficult and costly to modify a 2.2T motor to significantly exceed the power of a 2.4 CIS engine. Again, best bet is to buy a good 2.7 engine, or rebuild one. -Wayne
GAFB
Several BMWs |
For sale Ready to run rebuilt 2.7 longblock So much temptation out there. EDIT: is there, or has there ever been, a CIS engine that works with ITBs, or is that purely a set-up for cars w/ a computer brain?
dave 1973,5 Last edited by }{arlequin; 12-15-2004 at 07:56 AM.. |
Great Post Dave
I am in the same boat with a 2.2T. I think a 3.0 will be my choice for purchase and rebuild. This will take a while so the 2.2l has to get kicking for now.
![]() http://members.cardomain.com/austin5522004
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
-Wayne
