H.G.P.'s Avatar
Riddle...or "What's not in Wayne's book"
Tops........Tops...........Tops
"Joker springs backwards to the Crown"
"Oil to the Crown"
"2 to the 2"
"Three to the E"
Tops.......Tops.......Tops
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 01-12-2005, 11:53 AM
adomakin's Avatar
what the £uck?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 01-12-2005, 01:03 PM
dtw dtw is offline
GAFB
You need to ventilate the garage when working with acetone and other cleaning supplies.
Did you ever measure your main bore.
Several BMWs
Old 01-12-2005, 02:34 PM
Doug Steinel's Avatar
comeon guys, give the man a break. Some porsche people are literate.
77 911, 3.0L
Old 01-12-2005, 05:09 PM
H.G.P.'s Avatar
Any takers?
Hint #1: Install (ation) of.........
1969 911 E Coupe
Old 01-12-2005, 07:56 PM
PRO Motorsports
Tyson Schmidt's Avatar
Sounds like how to install rings properly.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-12-2005, 09:23 PM
H.G.P.'s Avatar
Just for my own thinking, I wanted a checklist to install my particular new rings the same way.
I wanted to be sure the oil spring break ("Joker") stayed opposite ("backward") of the ring (which surrounds and "holds it) gap holding it. (The spring reminds me of a joker's hat.) The oil ring gap staying toward the top ("Crown, in this case, meaning cooresponding to the piston valve large relief cutout" 4-7 Wayne's book)
The second #2 ring, on my pistons, the ring gap I coorespond toward the number 2 side of the piston, which is stamped on the right side on my pistons. So 2 gap to the 2 side.
And then the #3 top comp. ring on my pistons, the gap cooresponds to the E (stamped on the piston) left side of the piston, which is opposite to the 2 ring. So "#3 to the E side.
Last, I double check that all rings top stampings face the "top" of the piston. 4-3 Wayne's book. (photo above does not show the bottom small relief cutout due to the magnifying)
For my own dazed thinking.......................
1969 911 E Coupe
Old 01-12-2005, 10:43 PM
adomakin's Avatar
flipping eck!
10 points for effort anyway!
Andy
Old 01-13-2005, 10:54 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Rings rotate when the engine runs so aside from installing the rings up side down you can hardly make a mistake.
Space the gaps so they don't all line up and you're go to go.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-13-2005, 11:17 AM
Banned
snowman's Avatar
Great!!! someone finally outdid my most outrageous post.
Old 01-14-2005, 06:11 PM
audi2.7t's Avatar
Originally posted by Wayne at Pelican Parts
*Everything* is covered in my book.
-Wayne
hmmm, how about disconecting the clutch on a G50 for engine removal ?, as far as I see it only covers a cable clutch. (101 projects)
p.s.
Judging by the amount of posts from HGP regarding your books maybe you could have him proof the next one...
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 01-14-2005, 08:48 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmmm, I'll leave that one alone. To clarify - everything is included in my "Engine Book." The 101 Book is a compromise book that couldn't possibly include all of the info that you would need for all cars 1965-89.
Henry and snowman are right - the rings to rotate in the grooves when the engines are running. Still, it's best to start them out opposite from each other with the oil ring on top.
-Wayne
Old 01-14-2005, 10:31 PM
