Mooncut cylinder ?
I'm wanting to boattail my case and mooncut my cylinders while my motor is apart.what are the measurements for moon cutting the cylinders.My Uncle owns a machine shop,so I do have access to the right equipment to do this?
Any info appreciated! Thanks! Charles |
Good question! I have wondered this myself.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Still Doin Time
I've heard here that the general concensus is that it will only benefit at higher (6K+)RPM's. That most street cars would not really 'see' gains.
I'm considering it as I would do most myself so just my labor involved. My school of thought is every little bit helps. Any one want to chime in?? Maybe Henry??
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Irrationally exuberant
I boat tailed the case on my 3.2 but I didn't touch the cylinders because they only stuck "out" a couple of millimeters. I probably wouldn't even bother with the boat tailing if I was doing it again.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Home of the Whopper
Stick the cylinder in the case. You can trace where you need to grind off.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
feed back I got from local experts was the boat tailing and mooning only came into effect after 7K+ rpm, maybe even 8K+ so fun to do, but the return is small beyond the bragging rights.
I boat tailed anyway. Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Try not, Do or Do not
All good advise.
For my money, both are a tremendous waste of time and will offer no benefit in all but the most extreme racing engines. We have not been able to measure a benefit on the dyno. That said, 14 mm deep by 70 mm wide. The pictures are of a cylinder from one of Dick Barbour's 935.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Still Doin Time
Henry, as always, not only are you informative, you are an honest guy which is a rare commodity in the car business.
Thanks, that saves me some work!!
Jeff
As far as arguments against it goes, the piston will stick that much farther out of the jug which will create extra piston stress and wear.
So essentially, all con, little to no pro. |
Author of "101 Projects"
I agree with Henry. Unless you're trying to extract one more 1/2 HP from a high-RPM race motor, it's really not worth it. I basically said this in the Engine Book too. Also included in this is boat-tailing - not a real good return on your time/effort/money.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Actually I don't think the piston will stick out at all there. The Mahle pistons have almost no skirt on the sides where the "moon" is.
-Andy
72 Carrera RS replica, Spec 911 racer |
