Mooncut cylinder ?
I'm wanting to boattail my case and mooncut my cylinders while my motor is apart.what are the measurements for moon cutting the cylinders.My Uncle owns a machine shop,so I do have access to the right equipment to do this?
Any info appreciated!
Thanks! Charles
Old 01-13-2005, 06:41 PM
Jeff Alton's Avatar
Good question! I have wondered this myself.
Jeff
www.turn3autosport.com
Old 01-13-2005, 08:09 PM
Still Doin Time
asphaltgambler's Avatar
I've heard here that the general concensus is that it will only benefit at higher (6K+)RPM's. That most street cars would not really 'see' gains.
I'm considering it as I would do most myself so just my labor involved. My school of thought is every little bit helps. Any one want to chime in?? Maybe Henry??
Old 01-14-2005, 07:23 AM
Irrationally exuberant
ChrisBennet's Avatar
I boat tailed the case on my 3.2 but I didn't touch the cylinders because they only stuck "out" a couple of millimeters. I probably wouldn't even bother with the boat tailing if I was doing it again.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-14-2005, 09:10 AM
Home of the Whopper
Stick the cylinder in the case. You can trace where you need to grind off.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 01-14-2005, 09:45 AM
addictionMS's Avatar
feed back I got from local experts was the boat tailing and mooning only came into effect after 7K+ rpm, maybe even 8K+ so fun to do, but the return is small beyond the bragging rights.
I boat tailed anyway.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 01-14-2005, 10:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
All good advise.
For my money, both are a tremendous waste of time and will offer no benefit in all but the most extreme racing engines. We have not been able to measure a benefit on the dyno.
That said, 14 mm deep by 70 mm wide.
The pictures are of a cylinder from one of Dick Barbour's 935.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-14-2005, 12:05 PM
Still Doin Time
Henry, as always, not only are you informative, you are an honest guy which is a rare commodity in the car business.
Old 01-14-2005, 02:02 PM
Jeff Alton's Avatar
Thanks, that saves me some work!!
Jeff
Old 01-14-2005, 02:25 PM
350HP930's Avatar
As far as arguments against it goes, the piston will stick that much farther out of the jug which will create extra piston stress and wear.
So essentially, all con, little to no pro.
Old 01-14-2005, 06:03 PM
Author of "101 Projects"
Wayne 962's Avatar
I agree with Henry. Unless you're trying to extract one more 1/2 HP from a high-RPM race motor, it's really not worth it. I basically said this in the Engine Book too. Also included in this is boat-tailing - not a real good return on your time/effort/money.
-Wayne
Old 01-14-2005, 10:38 PM
Actually I don't think the piston will stick out at all there. The Mahle pistons have almost no skirt on the sides where the "moon" is.
-Andy
Old 01-14-2005, 10:47 PM
