Installing piston rings with oil?
Should I coat the piston ring gaps and the 3 rings with oils when installing the piston into the cylinder?
thanks,
anthony
Old 04-10-2005, 10:23 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Yep, clean oil
Scott Kinder
kindersport @ gmail.com
Old 04-11-2005, 12:06 AM
Thanks. That is what I thought but wanted to comfirm.
Old 04-11-2005, 06:40 AM
350HP930's Avatar
A light oil without any friction modifiers like molly is preferred. During the quick initial break part of the break in process you don't want the rings to be too slick.
Tranny fluid makes a good initial oil for the rings. Some engine builders use marvels mystery oil.
We use non detergent 20 weight where I currently work.
Old 04-11-2005, 05:36 PM
Banned
snowman's Avatar
Additional note. Not need to use to much either, as the excess just runs off. Just place the palm of your hand into the oil and wipe it across the piston and rings before installing. Some dip the piston and rings into a can of oil--- to much as it just runs off.
I actually wipe off the piston and rings with an oiley cloth, so they are almost dry. More oil than this is not going to do much of anything but possibly foul the plug.
Old 04-11-2005, 11:02 PM
Irrationally exuberant
ChrisBennet's Avatar
I don't oil the rings directly but I wipe some oil on the inside of the ring compressor so the rings will slide out easier.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-12-2005, 05:36 AM
Is the object to have the rings running against the walls for a few seconds with effectively no oil? Won't they get "oiled" as the car builds pressure in the system?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 04-29-2008, 11:51 AM
No. Oil is quite necessary to reduce friction and prevent excessive wear. The break-in process includes oil to remove metal particles as well.
Yes, but if the lube system isn't primed or fully primed, it'll take a few seconds for pressure to build and oil to flow normally. Meanwhile, pistons are moving up and down at the crankshaft rate of maybe 1500 rpm. That's a lot of sliding with minimal oil film.
Sherwood
Old 04-29-2008, 02:34 PM
911 tweaks's Avatar
what does one do if the build process takes 1-2 weeks??
Squirt oil into the spark plug holes just prior to attempting to start?
Bob
I live for 911 tweaks...
Old 04-29-2008, 03:11 PM
911 tweaks's Avatar
uuuuuhhhhhhhhhhhoooooooooo
I just hit the magical quantity of "911" posts... do I win anything?? Wayne are you reading this?
Bob
Old 04-29-2008, 03:13 PM
Bob
Remove spark plugs, crank engine w/o spark to build pressure, squirt lube into the SP holes.
Sherwood
Old 04-29-2008, 03:21 PM
911 tweaks's Avatar
thanks Sherwood for the reply... I have a few more posts to make to catch up with you I can see :-) Bob
Old 04-29-2008, 04:08 PM
Banned
snowman's Avatar
More oil is not really necessary or desirable. Yes some oil must be on the cylinder walls, otherwise the rings could be damaged or the cylinder or both. But very little oil is required. Remember a well built engine uses almost no oil, extra oil is just burnt, creating carbon, a nasty byproduct that is to be avoided. 912 race engines using chrome rings do not break in if to much oil is used, some actually build their engines bone dry. I do not agree with bone dry, some oil is necessary to prevent galling.
Bottom line. Use an oily cloth to wipe down the cylinders on assembly. also use a hand full of oil to wipe across the piston and rings as you assemble it, thats enough. If you start the thing up within a couple of months you should be ok, more time than that, yes squirt some oil into the cylinders and cycle the engine a few times without the plugs before starting. More than a couple of months is a bad idea for any engine to sit before starting, lubes, even assembly lube dry out. If it has sat for a long time, cycle the engine, without plugs for a long time, like several minutes to 10's of minutes to get the oil circulating. Remove a valve cover and cycle the thing enough to see oil on every rocker. A chevy has an oil pump that can be used to prime the engine, a Porsche cannot be primed this way, it just has to be turned over, but without plugs, ie no load, to prime it.
Bottom line. Assemble the engine and get it started within a month to 6 weeks.
Old 04-29-2008, 09:02 PM
I'll reiterate what Jack said- don't run the cylinders dry. It's hell on the rings and on the nikasil. About the only time I've had cylinders come back for warranty work is from improper cleaning or lack of oil on the bores/rings/pistons during installation.
I personally use a mix of Brad Penn 30wt and Red STP (or EOS), as my pre-lube.
As far as cleaning, I tell my customers to clean with chemwipes (lint-free paper, white) with denatured alcohol, until the wipes come out as white as they went in. Suprisingly, it takes alot more passes than one would think to get all the honing dust/oil mess out of the bores.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 04-30-2008, 12:11 PM
dtw dtw is offline
GAFB
Charles,
Agreed, I just cleaned up a set of new Nikasils and was shocked. Took several wipes and solvent on each cylinder to get them cleaned out. Very glad I didn't run them as-is.
When you use this pre-lube (I can probably just use some BP break-in oil), do you apply it very lightly? Basically just a light wipe-down with a towel?
Several BMWs
Old 04-30-2008, 12:43 PM
Yup, just a light wipe down from a towel with a good amount of oil in/on it. Then I use a small squirt bottle to oil the rings & lands. A small brush (that you know doesn't loose bristles) is an easy applicator as well. A little bit of oil isn't going to change how the rings seat, at least with the experience I've had with nikasil bores. For sure, iinstalling dry is about the worst thing you could do :-)
Charles Navarro
Old 04-30-2008, 12:59 PM
Fast Corners's Avatar
I install the rings on the piston dry. I feel that when I put them on dry I have more control over how they go onto the piston. Once they are on the piston, I drip oil onto them and spin the rings back and forth to distribute the oil on them and the lands.
I then put them on the rod, wipe a thin layer of oil on the cylinder bore then install the cylinder. When they are all on I turn the motor by hand and wipe the excess oil out of the cylinder with a lint free wipe. Not too much oil, not to little...just right.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 05-02-2008, 10:26 AM
Yes, good clarification. Installing the rings dry is preferred, so you have more feel - then oil after installed on the piston. I've never tried to install an oiled ring onto a piston, but I would imagine it might make the task a bit harder (and more likely to damage something).
It's for that same reason, I know engine builders that don't use thick assembly lubes, preferring just a mix of 30wt and EOS (or Red STP), as they prefer to be able to 'feel' how the engine is going together and how it turns over, prior to initial startup and break-in.
Charles Navarro
Old 05-02-2008, 05:04 PM
