mingmong's Avatar
Novice questions...
Firstly. How do I find out which Distibutor rotor is the correct one for my engine? It's a 1977 Carrera 3.0. Apparently there are several different 'cut off rpm' types. 6900rpm, 7000rpm, 7200rpm etc.
Secondly. Is it possible to replace the seal which is situated just behind the pulley on the engine (main bearing number1?) without dismantling the entire engine. (Sorry about my discription...you can tell I haven't done this before!). It appears to be the source of a leak.
Thirdly. How do you remove said pulley off the engine? Is it difficult?
Cheers M
Old 04-26-2005, 12:16 AM
Irrationally exuberant
ChrisBennet's Avatar
The "pulley seal" as it's called is inside the #8 bearing. Often there is a leak between the outside of the #8 bearing and the case. That seal (an O-ring) can't be replaced without splitting the case but you may have some luck sealing it.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-26-2005, 04:58 AM
mingmong's Avatar
OK. Wrong decription on my part! I was talking about the 'front crankcase oil seal' (pulley end). Just read the Bentley Bible and on page 130-2 it says you can replace this. Need some special tools and luck getting the pulley off but it can apparently be done without splitting the engine. Give it a go!
Can anyone help me on the Distributor Rotor type?
Thanks M
Old 04-26-2005, 11:25 PM
Just be aware that oil in that area can come from 2 places. I'd clean the area thoroughly and run it a bit before you take things apart so you can see where the leaks are.
-Chris
Old 04-27-2005, 03:53 AM
mingmong's Avatar
Thanks. I shall do. Mine looks just like your picture. Nice to know I'm not alone eh! M
Old 04-27-2005, 04:19 AM
mingmong's Avatar
Many thanks everyone for your input. One 7000rpm rotor on order. Pics of my car will be arriving soon. I've also got your book on order Wayne...think I'm going to need it the further down this rebuild road I go!
M
Old 05-01-2005, 12:15 AM
