Novice questions...
Firstly. How do I find out which Distibutor rotor is the correct one for my engine? It's a 1977 Carrera 3.0. Apparently there are several different 'cut off rpm' types. 6900rpm, 7000rpm, 7200rpm etc.
Secondly. Is it possible to replace the seal which is situated just behind the pulley on the engine (main bearing number1?) without dismantling the entire engine. (Sorry about my discription...you can tell I haven't done this before!). It appears to be the source of a leak. Thirdly. How do you remove said pulley off the engine? Is it difficult? Cheers M |
Irrationally exuberant
The "pulley seal" as it's called is inside the #8 bearing. Often there is a leak between the outside of the #8 bearing and the case. That seal (an O-ring) can't be replaced without splitting the case but you may have some luck sealing it.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
OK. Wrong decription on my part! I was talking about the 'front crankcase oil seal' (pulley end). Just read the Bentley Bible and on page 130-2 it says you can replace this. Need some special tools and luck getting the pulley off but it can apparently be done without splitting the engine. Give it a go!
Can anyone help me on the Distributor Rotor type? Thanks M |
![]() Just be aware that oil in that area can come from 2 places. I'd clean the area thoroughly and run it a bit before you take things apart so you can see where the leaks are. -Chris
Thanks. I shall do. Mine looks just like your picture. Nice to know I'm not alone eh! M
Author of "101 Projects"
You need to get an Engine Rebuild Book first - http://www.101projects.com - all the answers are in there...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Many thanks everyone for your input. One 7000rpm rotor on order. Pics of my car will be arriving soon. I've also got your book on order Wayne...think I'm going to need it the further down this rebuild road I go!
M |
