OldTee's Avatar
Oil lines with SSIs
Could someone post a picture showing the location of the oil lines on a 3.0 SC engine being updated (downdated) with new SSI heat exchangers. I am about to mount the exchangers and it looks like it might be easier to install one of the oil lines now rather than later. I know I can figure it out with the engine installed but I am hoping a picture will save some time later. Thanks
Old Tee
all 911s sold
Old 05-31-2005, 02:26 PM
The line that mounts to the engine needs to be installed prior to the SSIs. The tab on the line attachs near the oil cooler. This photo shows a small portion of the lines location.
Kevin
'79 Coupe
Old 05-31-2005, 04:12 PM
BReyes's Avatar
Follow the picture above closely and you will see how it differs from the line you have now.
Yes you need a need line with SSI.
Regards,
Bernard
Old 05-31-2005, 11:07 PM
BReyes's Avatar
a new line
Bernard
Old 05-31-2005, 11:08 PM
OldTee's Avatar
Just what I needed. Thanks.
Old Tee
all 911s sold
Old 06-01-2005, 04:18 AM
Bill Verburg's Avatar
A pic from below
and the wheel well area
Bill Verburg
Old 06-01-2005, 02:14 PM
