3.0L turbo case (Euro Carrera)
I've come across one of these cases but wanted to confirm the ser. #. According to the Red Book the case # shows as a Aug. 75-July '76 US Turbo case. Is this the same as the Euro Carrera case. What is the going price? I thought about using this as a basis for a short stroke 2.8.
'74 rsr w/2.8 (w/pulled head studs) |
The case is the same but many of the other components like heads, f/w etc. were different.
The case # I have is 6860236. I found this old thread that mentioned a different case #:
the cases you are looking for should have engine type # 930/02 and 930/12 with serial no. 666XXXX or 667XXXX The same case is used in the 76-77 turbo, engine type 930/52
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
