Engine mount stud needed
I need a stud for shorter engine (fan end).
What are the spec on it? It seems to be a 10x? Also where is a good place to get them. Should the local FLAPS have them? Cheers
Kerry (Back on the road, sort of) 914-6 in the Werks |
Irrationally exuberant
Your description is a little vague. You might be able to find the stud you want at metric hardware place but you may be able to get something from Pelican. Try looking it up here:
911 Engine Catalog Note: The stud length in the catalog (and Porsche's own parts catalog) is the amount of stud exposed when installed not the overall length. If you buy the studs from someplace else the length with be the overall length. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 08-28-2005 at 06:04 PM.. |
Good tip Chris, I didn't know about the length tid bit. I was down at my local parts place and we were having a discussion about exhuast studs for a late SC and he kept saying they are XX length and XX was what I measured to be sticking out......... was not making sense. They had what were suppossed to be the right ones and when I measured them, XX was the overall length.... Funny part is, they didn't know either and had a whole bunch of studs that were too short!
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
