loctite 574 removing
Hello
Sorry to ask again, but i didn't find threads to explain how to remove "faster" the 30 years old sealant of my RS engine....
many thanks for advices or links.
Philippe
Old 08-29-2005, 03:56 AM
Irrationally exuberant
ChrisBennet's Avatar
Phillipe, I found a couple:
Removing sealant between the case halves
crank case cleaning
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-29-2005, 04:06 AM
Chris
your a kind guy as you almost answer all my questions.
You're welcome home if you have a trip to taste burgundy wines.
Philippe
Old 08-29-2005, 04:36 AM
Originally posted by philippeF
Chris
Philippe
Sound good!
The gasket remover is also known as Loctite 80646. In case you can't find Permatex, Wurth has a similar product. I haven't tried the Wurth gasket remover but it wouldn't surprise me if it was exactly the same stuff with a different label. I know Wurth sells Loctite 574 under their own label.
-Chris
Old 08-29-2005, 05:17 AM
