LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
911T into 2.8
Henry,
Thanks for the input. The car is with Dave at TRE. He has redone the suspension and brakes ... I will run the Targa Cali this year and then focus on the engine. You pretty much have confirmed what I "thought". Like I said I have seen a car done with a 7R, it was an old build but cool.
Hopefully when I come out for the Targa I can stop by your shop and discuss a build if your schedule allows.
Thanks again.
Chris
Old 04-07-2019, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #221 (permalink)
Walt Fricke's Avatar
Henry - getting a 95mm cylinder to fit in a 7R (or earlier) case spigot sounds like it calls for more than a little ingenuity!
The 93mms got awfully thin down in the spigot, didn't they? Maybe still had enough left to remove another 1mm each side? But the stud spacing? There is enough meat up there where it matters to narrow the distance between the stud borings and the wall that extra mm? Wow
The SS is that much better than the LS a guy could have for a lot less work/$ (unless he bought real 2.8 heads, of course)?
Old 04-07-2019, 09:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #222 (permalink)
Gon fix it with me hammer
svandamme's Avatar
anything is possible on a 7R bit if you throw enough money at it
but calling that "keep it simple" ??
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-07-2019, 11:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #223 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
After living in the back of a 935, this little gem is heading home.
The 935 is getting a proper turbo.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-15-2025, 12:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #224 (permalink)
911 tweaks's Avatar
Henry... is your just posting on this old thread relevent to the other thread looking for out of the box engine build ideas...? just curious...
I live for 911 tweaks...
Old 08-15-2025, 12:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #225 (permalink)
Not related.
It looks like the turbo we will be building is a pretty straight forward mid 80s 375hp CIS engine.
Clean exhaust, sport muffler, slight porting, K27, SC cams and a little more compression. Basically make a 3.3, low compression (8.0:1?) SC that kicks in limited boost from the turbo at around 2600. Big inter-cooler is must.
Big torque and a very driveable package.
Henry Schmidt
Ph: 760-728-3062
Old 08-15-2025, 01:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #226 (permalink)
