964 engine build questions
1. Does the 964 3.6L engine require copper base gaskets between the cylinders and case, or does it only use the o-ring?
2. When looking at the 964 pistons, I don't see a good mark to indicate how the piston should be oriented when installed. What should I look for on the piston to determine the proper orientation for the piston when installing.
Thanks,
Brian
Brian Keith Smith
Old 09-18-2005, 07:27 PM
Irrationally exuberant
ChrisBennet's Avatar
(1) The base just uses an O-ring - though it wouldn't hurt to use a little Threebond 1211 too.
(2) The intake side/"top" of the piston has a letter "E"
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-18-2005, 07:33 PM
Thanks Chris.
Brian
Brian Keith Smith
Old 09-19-2005, 03:47 AM
Chris:
What are the head stud torque specs on the 964 using the stock head studs/nuts/washers?
Brian
Brian Keith Smith
Old 09-19-2005, 03:25 PM
Brian if you dont have the specs before tomm I will get them from my house
Eric Hood
Old 09-19-2005, 06:43 PM
Originally posted by briankeithsmith
Chris:
Brian
Old 09-19-2005, 07:27 PM
Thanks guys.
Brian Keith Smith
Old 09-20-2005, 05:02 AM
