resident samsquamch
sand_man's Avatar
3.3 fully finned cylinders
I'm in the process of rebuilding my 1987 930 and am considering the use of the 965 style fully finned cylinders. My engine only has 42,000 miles and I'm pretty sure that the pistons can be re-used (with new rings). Can JUST the cylinders be ordered or can I only get the kit? Approximately how much $$$? Not sure I'll have the budget for "Nickies", and I think the basic Mahle 965 cylinders would be a sufficient upgrade. Please advise.
Thanks,
Jeff
Old 11-30-2005, 09:56 AM
I'm not aware of anyone selling just Mahle cylinders unless they have a broken set or not. You may want to place a classified ad out there to see if you can find a good set, although there is no guarantee that they will be an exact fit. Make sure to measure your pistons and existing cylinders so you have a baseline to compare to the replacements. You can always coat the skirts to close up the clearance, but in my experience the sacrificial nature of the skirt coatings don't make this solution a particularly long lived one.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 11-30-2005, 05:18 PM
resident samsquamch
sand_man's Avatar
Thanks for taking the time to respond, Charles!
Old 11-30-2005, 06:18 PM
resident samsquamch
sand_man's Avatar
Just out of curiosity, how much am I looking at for a set of your cylinders, Charles? For a 3.3 930.
Old 11-30-2005, 06:28 PM
89turbocabmike's Avatar
Jeff, if you can't find some 965 cylinders another option would be 3.2 cylinders bored and replated to match you pistons.
Old 11-30-2005, 08:56 PM
Irrationally exuberant
ChrisBennet's Avatar
There are 4 different diameter tolerance groups for the Porsche cylinders. Someone with a good selection of them (EBS?) might be able to get you a matching set but it would be long shot.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-03-2005, 11:57 AM
Forced Induction Junkie
WERK I's Avatar
If you use the 965 cylinders, don't forget the viton O-rings that fit in the cylinder bases. It will leak like crazy otherwise.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-03-2005, 02:03 PM
