Puny Bird
Mark Henry's Avatar
Originally Posted by khamul02 View Post
Questions on a 11 year old post...
I'm thinking about using threaded plugs. Is using stainless plugs ok given the different expansion rates.. Several people have used them so at this point I would think someone could chime in.
If I go forward will these plugs and tap do the job?
https://www.amazon.com/Century-Drill-Tool-95201-Plug/dp/B004UUAMK4
https://www.amazon.com/Metalwork-Stainless-Steel-Fitting-Countersunk/dp/B07DDN298N
I just use the steel plugs:
-The hex doesn't strip out, like with aluminum or the brass plugs.
-SS has a tendency to gall, BTW I'd try MOM as an anti seize, good enough for jet engines.
-SS is hard, worst case I could drill out the steel easier.
I do the 5 steel 3/8" NPT plugs in type 4 cases all the time, the different expansion rates have never been an issue.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-09-2021, 05:29 PM
Tags
cam carriers
